The user-guide states:
" To connect to a monitor or TV that only accepts HDMI, you can use an active adaptor/cable that converts DisplayPort to HDMI."
I already tried 2 but none of them is working. Which active adapters are compatible with Orin platform?
Hi manthey,
We’re using this one DP to HDMI cable, it’s working on AGX-Orin.
Thank you. I just bought this one. Works too. Be careful when unplugging. Make sure to press the release button first.
