Which CAMERA module models are ORIN EVK supported by default ??
hello channinglan,
if you have the camera board works with Xavier series. the same camera board will fit the J509 camera connector and it works on Orin.
you may also check Jetson Partner Supported Cameras on the Jetson platforms.
thanks
Unable to insert CAMERA module 699-83326-1000-100 M to ORIN
The button mechanism is too high
So I want to buy other CAMERA modules that can be used on ORIN for verification
hello channinglan,
you need to disassemble the developer kit to make the camera board fits camera connector.
however, there’s known issue only IMX274 works on JP-5.0/Orin. we’re tracking this internally.
only IMX274 works on JP-5.0/Orin ???
So other models don’t work ???
hello channinglan,
there’s known issue with camera module detection, so far, only IMX274 driver being detected with JP-5.0.
Where can I buy CAMERA that is sure to work ??
hello channinglan,
note, this is “Developer Preview” version, there’re some known issues, please targeted for fix in JetPack-5.0 production release.
