Which detection model will give more accuracy for arial view image detection!
Hi samjith888,
As mentioned previously, you need to trigger experiments.To improve accuracy on small objects, the most common trick is to use a smaller set of anchors. The anchor sizes should have a size that is similar to the small objects’ size. Anchor ratios can be kept unchanged.
You can also train only two classes firstly instead of 5 classes. Trigger less classes in order to narrow down.
Mssing_P 25x23
Extra_P 26X13
Note that for above size, since you change from 40962160 to 1024544, you need to make anchor sizes cover
25/4 * 23/4
26/4 * 13/4
How to change the anchor sizes to cover the above anchor sizes?
anchor_box_config {
scale: 8.0
scale: 16.0
scale: 32.0
ratio: 1.0
ratio: 0.5
ratio: 2.0
Refer to the way in https://devtalk.nvidia.com/default/topic/1069737/transfer-learning-toolkit/which-detection-model-will-give-more-accuracy-for-arial-view-image-detection-/post/5420836/#5420836,
for the two small objects,
Mssing_P 25x23
Extra_P 26X13
since you change from 4096x2160 to 1024x544, so it becomes
6.25x5.75
6.5x3.25
You can try
anchor_box_config {
scale: 4.0
scale: 4.6
scale: 5.0
ratio: 1.0
ratio: 0.5
ratio: 2.0
It can cover anchor sizes like
4x4,
2.828x5.656
5.656x2.828
4.6x4.6
3.25x6.5
6.5x3.25
5x5
3.535x7.07
7.07x3.535
can i use different resolution images for training ?
Sure, you can set your original resolution to others.
Then calculate the new pixels range of the small objects. And set a better anchor_box_config.
Hi Morganh,
I meant that i have a data set which consist of images with different resolutions ( eg:41202240, 800450, 1080120 ,300 250 etc). So can i use this dataset for training? Or TLT didn’t only unique sized images ?
For detectnet_2 and SSD network, all of the images must be resized offline to the final training size.
For faster-rcnn, you don’t need to resize the image.
See tlt user guide’s chapter 2 for more details.
