Morning!
I failed to start the Nucleus and Issac Sim.(Please see the Picture attached). And I found that some topic shows same problem,some said one possible is the the version of nvidia driver is too high.
which driver should I choose?
The IsaacSim version is 2023.1.1 and the Nucleus version is 2023.2.3
My gpu is 4060laptop,and my driver is 31.0.15.4680.
thanks!
I think you are getting a couple of things mixed together. Let’s take everything one step at a time.
Apps = run the latest version of Issac Sim which is 2003.1.1, so you are good there
Running this has nothing to do with Nucleus. You can just run it without. Does it run ?
Nucleus should give you a warning if it is out of date. You will get a green indicator. If it does not work, it may be a temporary issue. Reboot the machine. You do not need it to run Issac Sim or any other apps.
