Environment:
- AGX Thor, JetPack 7.0
- Holoscan SDK 3.9.0
- HSB 2.5.0 (2.5-GA)
- holohub tag: holoscan-sdk-3.9.0
I am trying to build the vb1940 ROS 2 publisher example on AGX Thor and hitting a build error
- error: ‘infiniband_devices’ is not a member of ‘hololink::core’
The example uses hololink::core::infiniband_devices() but all public Holoscan Sensor Bridge releases (2.5.0, 2.5.0-PB6, 2.6.0-EA, 2.6.0-EA2) only have hololink::infiniband_devices().
I checked all holohub tags from holoscan-sdk-3.6.0 to holoscan-sdk-4.3.0 — the file has never been updated.
My question:
What is the correct combination of:
- holohub release tag
- Holoscan Sensor Bridge release tag
- JetPack version (7.0 / 7.1 / 7.2)
…to successfully build and run the vb1940 ROS 2 publisher example on AGX Thor?
Also, the HSB 2.5-GA release notes state “Container builds for Thor for use with Linux network receiver applications only.” — does this mean the holohub vb1940 example (which uses RoceReceiverOp) is not supported on Thor, and examples/linux_vb1940_player.py from the HSB repo should be used instead?
