which is the IMX219 reset pin?
I know the imx219 can support for Jetson TX2 and use E3322 board,but I can not find the reset pin in the dtsi file.
which is the IMX219 reset pin? eveyone who can tell me?
this two file is the dtsi file.
* Copyright (c) 2016-2017, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; version 2 of the License.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
#include "t18x-common-platforms/tegra186-quill-camera-e3326-a00.dtsi"
#include "t18x-common-platforms/tegra186-quill-camera-e3323-a00.dtsi"
#include "t18x-common-platforms/tegra186-quill-camera-e3333-a00.dtsi"
#include "t18x-common-platforms/tegra186-quill-camera-e3322-a00.dtsi"
#include "t18x-common-platforms/tegra186-quill-camera-li-mipi-adpt-a00.dtsi"
#include "t18x-common-platforms/tegra186-quill-camera-imx274-a00.dtsi"
#include "t18x-common-platforms/tegra186-quill-camera-vivid.dtsi"
#define CAM0_RST_L TEGRA_MAIN_GPIO(R, 5)
#define CAM0_PWDN TEGRA_MAIN_GPIO(R, 0)
#define CAM1_RST_L TEGRA_MAIN_GPIO(R, 1)
#define CAM1_PWDN TEGRA_MAIN_GPIO(L, 6)
tegra-camera-platform {
* tpg_max_iso = <>;
* Max iso bw for 6 streams of tpg
* streams * nvcsi_freq * PG_bitrate / RG10 * BPP
* 6 * 102Mhz * 32 bits/ 10 bits * 2 Bps
* = 3916.8 MBps
tpg_max_iso = <3916800>;
/* set camera gpio direction to output */
gpio@2200000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_RST_L 0 CAM0_PWDN 0
CAM1_RST_L 0 CAM1_PWDN 0>;
label = "cam0-rst", "cam0-pwdn",
"cam1-rst", "cam1-pwdn";
/* all cameras are disabled by default */
host1x {
vi_base: vi@15700000 {
ports {
vi_port0: port@0 {
status = "disabled";
vi_in0: endpoint {
vi_port1: port@1 {
vi_in1: endpoint {
vi_port2: port@2 {
vi_in2: endpoint {
vi_port3: port@3 {
vi_in3: endpoint {
vi_port4: port@4 {
vi_in4: endpoint {
vi_port5: port@5 {
vi_in5: endpoint {
csi_base: nvcsi@150c0000 {
csi_chan0: channel@0 {
ports {
csi_chan0_port0: port@0 {
csi_in0: endpoint@0 {
csi_chan0_port1: port@1 {
csi_out0: endpoint@1 {
csi_chan1: channel@1 {
ports {
csi_chan1_port0: port@0 {
csi_in1: endpoint@2 {
csi_chan1_port1: port@1 {
csi_out1: endpoint@3 {
csi_chan2: channel@2 {
ports {
csi_chan2_port0: port@0 {
csi_in2: endpoint@4 {
csi_chan2_port1: port@1 {
csi_out2: endpoint@5 {
csi_chan3: channel@3 {
ports {
csi_chan3_port0: port@0 {
csi_in3: endpoint@6 {
csi_chan3_port1: port@1 {
csi_out3: endpoint@7 {
csi_chan4: channel@4 {
ports {
csi_chan4_port0: port@0 {
csi_in4: endpoint@8 {
csi_chan4_port1: port@1 {
csi_out4: endpoint@9 {
csi_chan5: channel@5 {
ports {
csi_chan5_port0: port@0 {
csi_in5: endpoint@10 {
csi_chan5_port1: port@1 {
csi_out5: endpoint@11 {
i2c@3180000 {
e3326_cam0: ov5693_c@36 {
e3323_cam0: ov23850_a@10 {
e3323_vcm0: lc898212@72 {
tca6408@21 {
tca9548@77 {
i2c@0 {
e3333_cam0: ov5693_a@36 {
e3322_cam0: imx219_a@10 {
i2c@1 {
e3333_cam1: ov5693_b@36 {
e3322_cam1: imx219_b@10 {
i2c@2 {
e3333_cam2: ov5693_c@36 {
e3322_cam2: imx219_c@10 {
i2c@3 {
e3333_cam3: ov5693_d@36 {
e3322_cam3: imx219_d@10 {
i2c@4 {
e3333_cam4: ov5693_e@36 {
e3322_cam4: imx219_e@10 {
i2c@5 {
e3333_cam5: ov5693_f@36 {
e3322_cam5: imx219_f@10 {
tca9546_70: tca9546@70 {
i2c@0 {
imx185_cam0: imx185_a@1a {
i2c@0 {
imx274_cam0: imx274_a@1a {
i2c@c240000 {
e3323_cam1: ov23850_c@36 {
e3323_vcm1: lc898212@72 {
tcp: tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
modules {
cam_module0: module0 {
cam_module0_drivernode0: drivernode0 {
cam_module0_drivernode1: drivernode1 {
pcl_id = "v4l2_lens";
cam_module1: module1 {
cam_module1_drivernode0: drivernode0 {
cam_module1_drivernode1: drivernode1 {
cam_module2: module2 {
cam_module2_drivernode0: drivernode0 {
cam_module2_drivernode1: drivernode1 {
cam_module3: module3 {
cam_module3_drivernode0: drivernode0 {
cam_module3_drivernode1: drivernode1 {
cam_module4: module4 {
cam_module4_drivernode0: drivernode0 {
cam_module4_drivernode1: drivernode1 {
cam_module5: module5 {
cam_module5_drivernode0: drivernode0 {
cam_module5_drivernode1: drivernode1 {
* Copyright (c) 2015-2016, NVIDIA CORPORATION. All rights reserved.
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
/* camera control gpio definitions */
host1x {
vi@15700000 {
num-channels = <6>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_vi_in0: endpoint {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_out0>;
port@1 {
reg = <1>;
e3322_vi_in1: endpoint {
csi-port = <1>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_out1>;
port@2 {
reg = <2>;
e3322_vi_in2: endpoint {
csi-port = <2>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_out2>;
port@3 {
reg = <3>;
e3322_vi_in3: endpoint {
csi-port = <3>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_out3>;
port@4 {
reg = <4>;
e3322_vi_in4: endpoint {
csi-port = <4>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_out4>;
port@5 {
reg = <5>;
e3322_vi_in5: endpoint {
csi-port = <5>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_out5>;
nvcsi@150c0000 {
num-channels = <6>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_csi_in0: endpoint@0 {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&e3322_imx219_out0>;
port@1 {
reg = <1>;
e3322_csi_out0: endpoint@1 {
remote-endpoint = <&e3322_vi_in0>;
channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_csi_in1: endpoint@2 {
csi-port = <1>;
bus-width = <2>;
remote-endpoint = <&e3322_imx219_out1>;
port@1 {
reg = <1>;
e3322_csi_out1: endpoint@3 {
remote-endpoint = <&e3322_vi_in1>;
channel@2 {
reg = <2>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_csi_in2: endpoint@4 {
csi-port = <2>;
bus-width = <2>;
remote-endpoint = <&e3322_imx219_out2>;
port@1 {
reg = <1>;
e3322_csi_out2: endpoint@5 {
remote-endpoint = <&e3322_vi_in2>;
channel@3 {
reg = <3>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_csi_in3: endpoint@6 {
csi-port = <3>;
bus-width = <2>;
remote-endpoint = <&e3322_imx219_out3>;
port@1 {
reg = <1>;
e3322_csi_out3: endpoint@7 {
remote-endpoint = <&e3322_vi_in3>;
channel@4 {
reg = <4>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_csi_in4: endpoint@8 {
csi-port = <4>;
bus-width = <2>;
remote-endpoint = <&e3322_imx219_out4>;
port@1 {
reg = <1>;
e3322_csi_out4: endpoint@9 {
remote-endpoint = <&e3322_vi_in4>;
channel@5 {
reg = <5>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_csi_in5: endpoint@10 {
csi-port = <5>;
bus-width = <2>;
remote-endpoint = <&e3322_imx219_out5>;
port@1 {
reg = <1>;
e3322_csi_out5: endpoint@11 {
remote-endpoint = <&e3322_vi_in5>;
i2c@3180000 {
tca9548@77 {
i2c@0 {
imx219_a@10 {
devnode = "video0";
compatible = "nvidia,imx219";
reg = <0x10>;
physical_w = "5.095";
physical_h = "4.930";
sensor_model ="imx219";
dovdd-supply = <&en_vdd_cam>;
avdd-reg = "vana";
dvdd-reg = "vdig";
iovdd-reg = "dovdd";
mode0 { // IMX219_MODE_3280X2464
mclk_khz = "24000";
num_lanes = "2";
discontinuous_clk = "yes";
cil_settletime = "0";
active_w = "3280";
active_h = "2464";
pixel_t = "bayer_rggb";
readout_orientation = "90";
line_length = "3448";
inherent_gain = "1";
mclk_multiplier = "25";
pix_clk_hz = "224000000";
min_gain_val = "1.0";
max_gain_val = "16.0";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1.462526";
max_framerate = "21";
min_exp_time = "13";
max_exp_time = "683709";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_imx219_out0: endpoint {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_in0>;
i2c@1 {
imx219_b@10 {
devnode = "video1";
reg = <0x10>;
avdd-reg = "vana";
dvdd-reg = "vdig";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_b";
active_w = "3280";
active_h = "2464";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_imx219_out1: endpoint {
csi-port = <1>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_in1>;
i2c@2 {
imx219_c@10 {
devnode = "video2";
reg = <0x10>;
avdd-reg = "vana";
dvdd-reg = "vdig";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_c";
active_w = "3280";
active_h = "2464";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_imx219_out2: endpoint {
csi-port = <2>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_in2>;
i2c@3 {
imx219_d@10 {
devnode = "video3";
reg = <0x10>;
avdd-reg = "vana";
dvdd-reg = "vdig";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_d";
active_w = "3280";
active_h = "2464";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_imx219_out3: endpoint {
csi-port = <3>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_in3>;
i2c@4 {
imx219_e@10 {
devnode = "video4";
reg = <0x10>;
avdd-reg = "vana";
dvdd-reg = "vdig";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_e";
active_w = "3280";
active_h = "2464";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_imx219_out4: endpoint {
csi-port = <4>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_in4>;
i2c@5 {
imx219_f@10 {
devnode = "video5";
reg = <0x10>;
avdd-reg = "vana";
dvdd-reg = "vdig";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_f";
active_w = "3280";
active_h = "2464";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_imx219_out5: endpoint {
csi-port = <5>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_in5>;
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <12>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e3322_bottomleft_A815P2";
position = "bottomleft";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "imx219 30-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@0/imx219_a@10";
drivernode1 {
module1 {
badge = "e3322_centerleft_A815P2";
position = "centerleft";
orientation = "1";
drivernode0 {
devname = "imx219 31-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@1/imx219_b@10";
drivernode1 {
module2 {
badge = "e3322_centerright_A815P2";
position = "centerright";
orientation = "1";
drivernode0 {
devname = "imx219 32-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@2/imx219_c@10";
drivernode1 {
module3 {
badge = "e3322_topleft_A815P2";
position = "topleft";
orientation = "1";
drivernode0 {
devname = "imx219 33-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@3/imx219_d@10";
drivernode1 {
module4 {
badge = "e3322_bottomright_A815P2";
position = "bottomright";
orientation = "1";
drivernode0 {
devname = "imx219 34-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@4/imx219_e@10";
drivernode1 {
module5 {
badge = "e3322_topright_A815P2";
position = "topright";
orientation = "1";
drivernode0 {
devname = "imx219 35-0036";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9548@77/i2c@5/imx219_f@10";
drivernode1 {
