Which Jetson-TX2-Series-Pinmux-Template.xlsm should I use?
I use Jetpack3.3,it download version R28.2.1 of linux and rootfs。
Can i use the latest Jetson-TX2-Series-Pinmux-Template.xlsm?
If we make changes based on Jetson TX2 Developer Kit baseboard, what other adaptations should we make besides modifying Jetson-TX2-Series-Pinmux-Template.xlsm?
HI,
Yes, please go ahead with this pinmux spreadsheet.
Please check the TX2 adaptation guide.
I modified pinmux xlsm file,generated and replaced cfg files,flash cfg by cmd(sudo ./flash.sh -r jetson-tx2 mmcblk0p1).
after the restart,i got flowing error logs,what happened?
[   26.798059] gk20a 17000000.gp10b: Timeout detected @ gr_gk20a_submit_fecs_method_op+0x104/0x274
[   26.807479] gk20a 17000000.gp10b: gr_gk20a_ctx_wait_ucode: timeout waiting on ucode response
[   26.816555] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_os_r : 0
[   26.824159] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_cpuctl_r : 0x40
[   26.832386] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_idlestate_r : 0x1
[   26.840706] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_mailbox0_r : 0x0
[   26.848968] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_mailbox1_r : 0x0
[   26.857186] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_irqstat_r : 0x0
[   26.865342] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_irqmode_r : 0x4
[   26.873450] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_irqmask_r : 0x8704
[   26.881832] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_irqdest_r : 0x0
[   26.889962] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_debug1_r : 0x40
[   26.898080] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_debuginfo_r : 0x0
[   26.906382] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_ctxsw_mailbox_r(0) : 0x10
[   26.915749] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_ctxsw_mailbox_r(1) : 0x0
[   26.925226] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_ctxsw_mailbox_r(2) : 0x41009
[   26.935343] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_ctxsw_mailbox_r(3) : 0x20
[   26.944470] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_ctxsw_mailbox_r(4) : 0x3ffd20
[   26.953963] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_ctxsw_mailbox_r(5) : 0x0
[   26.962949] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_ctxsw_mailbox_r(6) : 0x0
[   26.971985] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_ctxsw_mailbox_r(7) : 0x0
[   26.981015] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_engctl_r : 0x0
[   26.989266] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_curctx_r : 0x0
[   26.997426] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: gr_fecs_nxtctx_r : 0x0
[   27.005595] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_IMB : 0xbadfbadf
[   27.014560] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_DMB : 0xbadfbadf
[   27.023551] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_CSW : 0xbadfbadf
[   27.032497] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_CTX : 0xbadfbadf
[   27.041590] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_EXCI : 0xbadfbadf
[   27.050747] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_PC : 0xbadfbadf
[   27.059665] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_SP : 0xbadfbadf
[   27.068585] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_PC : 0xbadfbadf
[   27.077528] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_SP : 0xbadfbadf
[   27.086443] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_PC : 0xbadfbadf
[   27.095494] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_SP : 0xbadfbadf
[   27.104475] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_PC : 0xbadfbadf
[   27.113464] gk20a 17000000.gp10b: gk20a_fecs_dump_falcon_stats: FECS_FALCON_REG_SP : 0xbadfbadf
[   27.122466] NV_PGRAPH_STATUS: 0xa1
[   27.126172] NV_PGRAPH_STATUS1: 0x0
[   27.129616] NV_PGRAPH_STATUS2: 0x0
[   27.133251] NV_PGRAPH_ENGINE_STATUS: 0x1
[   27.137472] NV_PGRAPH_GRFIFO_STATUS : 0x1
[   27.141676] NV_PGRAPH_GRFIFO_CONTROL : 0x10001
[   27.146461] NV_PGRAPH_PRI_FECS_HOST_INT_STATUS : 0x0
[   27.151660] NV_PGRAPH_EXCEPTION  : 0x0
[   27.155610] NV_PGRAPH_FECS_INTR  : 0x0
[   27.159593] NV_PFIFO_ENGINE_STATUS(GR) : 0x80000000
[   27.164677] NV_PGRAPH_ACTIVITY0: 0x0
[   27.168427] NV_PGRAPH_ACTIVITY1: 0x600
[   27.172371] NV_PGRAPH_ACTIVITY2: 0x0
[   27.176149] NV_PGRAPH_ACTIVITY4: 0x0
[   27.179981] NV_PGRAPH_PRI_SKED_ACTIVITY: 0x0
[   27.184466] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_ACTIVITY0: 0x0
[   27.189977] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_ACTIVITY1: 0x0
[   27.195453] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_ACTIVITY2: 0x0
[   27.200992] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_ACTIVITY3: 0x0
[   27.206436] NV_PGRAPH_PRI_GPC0_TPC0_TPCCS_TPC_ACTIVITY0: 0x0
[   27.212330] NV_PGRAPH_PRI_GPC0_TPC1_TPCCS_TPC_ACTIVITY0: 0x0
[   27.218184] NV_PGRAPH_PRI_GPC0_TPCS_TPCCS_TPC_ACTIVITY0: 0x0
[   27.224047] NV_PGRAPH_PRI_GPCS_GPCCS_GPC_ACTIVITY0: 0x0
[   27.229449] NV_PGRAPH_PRI_GPCS_GPCCS_GPC_ACTIVITY1: 0x0
[   27.234922] NV_PGRAPH_PRI_GPCS_GPCCS_GPC_ACTIVITY2: 0x0
[   27.240356] NV_PGRAPH_PRI_GPCS_GPCCS_GPC_ACTIVITY3: 0x0
[   27.245790] NV_PGRAPH_PRI_GPCS_TPC0_TPCCS_TPC_ACTIVITY0: 0x0
[   27.251791] NV_PGRAPH_PRI_GPCS_TPC1_TPCCS_TPC_ACTIVITY0: 0x0
[   27.257738] NV_PGRAPH_PRI_GPCS_TPCS_TPCCS_TPC_ACTIVITY0: 0x0
[   27.263618] NV_PGRAPH_PRI_BE0_BECS_BE_ACTIVITY0: 0x0
[   27.268868] NV_PGRAPH_PRI_BE1_BECS_BE_ACTIVITY0: 0x0
[   27.274060] NV_PGRAPH_PRI_BES_BECS_BE_ACTIVITY0: 0x0
[   27.279211] NV_PGRAPH_PRI_DS_MPIPE_STATUS: 0x0
[   27.283857] NV_PGRAPH_PRI_FE_GO_IDLE_TIMEOUT : 0x800
[   27.289016] NV_PGRAPH_PRI_FE_GO_IDLE_INFO : 0x23000700
[   27.294376] NV_PGRAPH_PRI_GPC0_TPC0_TEX_M_TEX_SUBUNITS_STATUS: 0x0
[   27.300796] NV_PGRAPH_PRI_CWD_FS: 0x201
[   27.304953] NV_PGRAPH_PRI_FE_TPC_FS: 0x3
[   27.309181] NV_PGRAPH_PRI_CWD_GPC_TPC_ID(0): 0x100
[   27.314187] NV_PGRAPH_PRI_CWD_SM_ID(0): 0x100
[   27.318753] NV_PGRAPH_PRI_FECS_CTXSW_STATUS_FE_0: 0x2000
[   27.324274] NV_PGRAPH_PRI_FECS_CTXSW_STATUS_1: 0x140
[   27.329440] NV_PGRAPH_PRI_GPC0_GPCCS_CTXSW_STATUS_GPC_0: 0x0
[   27.335328] NV_PGRAPH_PRI_GPC0_GPCCS_CTXSW_STATUS_1: 0x300
[   27.341021] NV_PGRAPH_PRI_FECS_CTXSW_IDLESTATE : 0xe
[   27.346176] NV_PGRAPH_PRI_GPC0_GPCCS_CTXSW_IDLESTATE : 0xf
[   27.351897] NV_PGRAPH_PRI_FECS_CURRENT_CTX : 0x800fa0c5
[   27.357415] NV_PGRAPH_PRI_FECS_NEW_CTX : 0x800fa0c5
[   27.362533] NV_PGRAPH_PRI_BE0_CROP_STATUS1 : 0x5f00000
[   27.367912] NV_PGRAPH_PRI_BES_CROP_STATUS1 : 0x5f00000
[   27.373265] NV_PGRAPH_PRI_BE0_ZROP_STATUS : 0x0
[   27.378048] NV_PGRAPH_PRI_BE0_ZROP_STATUS2 : 0x0
[   27.382903] NV_PGRAPH_PRI_BES_ZROP_STATUS : 0x0
[   27.387642] NV_PGRAPH_PRI_BES_ZROP_STATUS2 : 0x0
[   27.392484] NV_PGRAPH_PRI_BE0_BECS_BE_EXCEPTION: 0x0
[   27.397633] NV_PGRAPH_PRI_BE0_BECS_BE_EXCEPTION_EN: 0x0
[   27.403061] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_EXCEPTION: 0x0
[   27.408571] NV_PGRAPH_PRI_GPC0_GPCCS_GPC_EXCEPTION_EN: 0x30000
[   27.414621] NV_PGRAPH_PRI_GPC0_TPC0_TPCCS_TPC_EXCEPTION: 0x0
[   27.420456] NV_PGRAPH_PRI_GPC0_TPC0_TPCCS_TPC_EXCEPTION_EN: 0x3
[   27.426619] gk20a 17000000.gp10b: gr_gk20a_fecs_ctx_image_save: save context image failed
[   27.439406] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_buffer: Invalid FECS local header: magic value
[   27.439406]
[   27.453370] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_pm_buffer: Lookup failed for address 0x500400
[   27.472582] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_buffer: Invalid FECS local header: magic value
[   27.472582]
[   27.484270] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_pm_buffer: Lookup failed for address 0x500400
[   27.502778] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_buffer: Invalid FECS local header: magic value
[   27.502778]
[   27.514585] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_pm_buffer: Lookup failed for address 0x500400
[   27.531067] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_buffer: Invalid FECS local header: magic value
[   27.531067]
[   27.542698] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_pm_buffer: Lookup failed for address 0x500400
[   27.553098] gk20a 17000000.gp10b: railgate is disabled.
[   27.593300] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_buffer: Invalid FECS local header: magic value
[   27.593300]
[   27.605165] gk20a 17000000.gp10b: gr_gk20a_find_priv_offset_in_pm_buffer: Lookup failed for address 0x500400
[   29.128444] CPU1: shutdown
[   29.131534] psci: CPU1 killed.
[   29.136519] NOHZ: local_softirq_pending 20
[   29.201957] CPU2: shutdown
[   29.204810] psci: CPU2 killed.
Ubuntu 16.04 LTS tegra-ubuntu ttyS0
tegra-ubuntu login: nvidia (automatic login)
Welcome to Ubuntu 16.04 LTS (GNU/Linux 4.4.38-tegra aarch64)
 * Documentation:  https://help.ubuntu.com/
618 packages can be updated.
301 updates are security updates.
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
[   30.969247] gk20a 17000000.gp10b: gk20a_set_error_notifier_locked: error notifier set to 8 for ch 507
[   30.978588] gk20a 17000000.gp10b: gk20a_fifo_handle_sched_error: fifo sched ctxsw timeout error: engine=0, tsg=0, ms=3100
[   30.978645] tegradc 15210000.nvdisplay: unblank
[   30.978824] ---- mlocks ----
[   30.978862]
[   30.978867] ---- syncpts ----
[   30.978913] id 18 (17000000.gp10b_507) min 2 max 4 refs 1 (previous client : )
[   30.979717]
[   30.979722] ---- channels ----
[   30.979759]
[   30.979759] channel 1 - 15820000.se
[   30.979759]
[   30.979765] NvHost basic channel registers:
[   30.979774] CMDFIFO_STAT_0:  00002040
[   30.979782] CMDFIFO_RDATA_0: 060045c4
[   30.979791] CMDP_OFFSET_0:   00000000
[   30.979797] CMDP_CLASS_0:    00000000
[   30.979803] CHANNELSTAT_0:   00000000
[   30.979809] The CDMA sync queue is empty.
[   30.979813]
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
[   30.979825]
[   30.979825] channel 2 - 15830000.se
[   30.979825]
[   30.979830] NvHost basic channel registers:
[   30.979837] CMDFIFO_STAT_0:  00002040
[   30.979843] CMDFIFO_RDATA_0: 046084d8
[   30.979851] CMDP_OFFSET_0:   00000000
[   30.979857] CMDP_CLASS_0:    00000000
[   30.979862] CHANNELSTAT_0:   00000000
[   30.979867] The CDMA sync queue is empty.
[   30.979871]
[   30.979881]
[   30.979881] channel 3 - 15840000.se
[   30.979881]
[   30.979885] NvHost basic channel registers:
[   30.979891] CMDFIFO_STAT_0:  00002040
[   30.979898] CMDFIFO_RDATA_0: de481c17
[   30.979906] CMDP_OFFSET_0:   00000000
[   30.979912] CMDP_CLASS_0:    00000000
[   30.979917] CHANNELSTAT_0:   00000000
[   30.979922] The CDMA sync queue is empty.
[   30.979925]
[   30.979944]
[   30.979944] ---- host general irq ----
[   30.979944]
[   30.979951] sync_intc0mask = 0x00000001
[   30.979959] sync_intmask = 0x50000003
[   30.979963]
[   30.979963] ---- host syncpt irq mask ----
[   30.979963]
[   30.979967]
[   30.979967] ---- host syncpt irq status ----
[   30.979967]
[   30.979977] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[   30.979985] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[   30.979992] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[   30.979998] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[   30.980005] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[   30.980011] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[   30.980018] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[   30.980024] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[   30.980031] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[   30.980037] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[   30.980044] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[   30.980052] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[   30.980059] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[   30.980065] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[   30.980072] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[   30.980079] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[   30.980085] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[   30.980092] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[   30.980120] 17000000.gp10b pbdma 0:
[   30.980121] id: 0 (tsg), next_id: 0 (tsg) chan status: valid
[   30.980145] PUT: 0000001e00008254 GET: 0000001e00000044 FETCH: 00000006 HEADER: 800302ec
[   30.980149]
[   30.980170] 17000000.gp10b eng 0:
[   30.980176] id: 0 (channel), next_id: 0 (tsg), ctx status: load
[   30.980180] busy
[   30.980181]
[   30.980197] 17000000.gp10b eng 1:
[   30.980201] id: 0 (tsg), next_id: 0 (tsg), ctx status: valid
[   30.980202]
[   30.980205]
[   30.980532] 507-17000000.gp10b, pid 1122, refs: 4:
[   30.980533] channel status:  in use on_pbdma_and_eng busy
[   30.980555] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[   30.980555] HEADER: 20400000 COUNT: 00000000
[   30.980555] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
[   30.980559]
[   30.980580] 508-17000000.gp10b, pid 1130, refs: 2:
[   30.980581] channel status:  in use idle not busy
[   30.980600] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[   30.980600] HEADER: 60400000 COUNT: 00000000
[   30.980600] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
[   30.980603]
[   30.980622] 509-17000000.gp10b, pid 1130, refs: 2:
[   30.980623] channel status:  in use idle not busy
[   30.980641] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[   30.980641] HEADER: 60400000 COUNT: 00000000
[   30.980641] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
nvidia@tegra-ubuntu:~$ [   30.980645]
[   30.980662] 510-17000000.gp10b, pid 1130, refs: 2:
[   30.980663] channel status:  in use idle not busy
[   30.980681] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[   30.980681] HEADER: 60400000 COUNT: 00000000
[   30.980681] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
[   30.980684]
[   30.980701] 511-17000000.gp10b, pid 1130, refs: 2:
[   30.980702] channel status:  in use idle not busy
[   30.980720] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[   30.980720] HEADER: 60400000 COUNT: 00000000
[   30.980720] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
[   30.980723]
[   30.981424] gk20a 17000000.gp10b: gk20a_fifo_handle_mmu_fault: fake mmu fault on engine 0, engine subid 0 (gpc), client 3 (l1 1), addr 0x00003834:0x3e6d1000, type 12 (bad kind), info 0x0100230c,inst_ptr 0x15105ca000
