which perform better between GEFORCE 940mx/1080ti and JETSON TX2?
a same algrithm run in different gpu,there is the tests i had done:
GEFORCE 1080ti[3854 cores,1582MHZ]:time slaps 200ms;
GEFORCE 940MX[384cores,1006MHZ]:time slaps 2890ms;
2890 / 200 = 38541582 / (3841006) may be sure.
Then,I need to run this algrithm in JETSON TX2[256 cores ,cannot find its frequency],the time[LET IT BE Tj] slaps will satisfy this :
Tj / 200 = 384 / 256
Q:the way i get the time slaps in JETSON TX2 is right? If not,how should i get it ?
PLus:if Tj is surely more than 200ms,it will be useless for me to run this algrithm in JETSON TX2.
I wouldn’t expect a TX2 to be as fast as a 1080Ti, running a CUDA kernel.
