Which regulator module is recommended to supply to my Jetson Orin Nano Super dev kit 8GB?
Hello, I need to put my Orin Nano Super on a battery-powered rover for object detection and 3D mapping. I have a few questions:
I want to set it to MAXN_SUPER and nothing less. Is it recommended or the cap 25W should be used instead ?
There is no specific limit like 40W of the NX for MAXN_SUPER, so if it is recommended, is there a good 45-48W regulator module I can use ?
The wattage chosen is similar to its 19V power supply, but to my understanding 9-19V, max 5A (written on the carrier board) can perform MAXN_SUPER and other modes as normal ?
I want to use 12V, and a Matek PDB FCHUB-12S V2 power distribution board (BEC 5V5A and 12V4A), it can also power the 4 motors, all from a big 12V battery. I had no problem with Matek boards, it’s a good brand, so I assumed its BEC voltage regulators are good. However, is it better to use 2 separate batteries and regulators, 1 for Jetson, and 1 for other hardware to avoid power spikes in case the Matek is bad ?
Thank you.
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
To supply power to your Jetson Orin Nano Super dev kit 8GB, it’s crucial to ensure that the power source is well-regulated and isolated to prevent damage from voltage or current spikes, especially since you’re planning to power it from a battery that also supplies other components like motors.
The Jetson Orin Nano specifications indicate that it can operate within a 5-20V input range. However, the quality of the power regulation is critical for the stable operation of the Jetson modules.
Given your setup, using a 12V supply with a good quality regulator is feasible, but it’s essential to ensure that the regulator can provide a stable output under various load conditions. The mention of a “MAXN_SUPER” mode suggests you’re looking to operate the Jetson Orin Nano at its maximum performance, which would require a reliable power supply.
For a 45-48W regulator module, the context provided does not specify particular models or brands recommended by NVIDIA for the Jetson Orin Nano. However, it emphasizes the importance of a well-regulated power supply.
Using a power distribution board (PDB) like the Matek PDB FCHUB-12S V2 with built-in BEC (Battery Eliminator Circuit) voltage regulators could work, given that Matek is considered a good brand and you’ve had positive experiences with their boards. The BEC on this board provides 5V and 12V outputs, which could be suitable for powering the Jetson Orin Nano and other components.
However, the question of whether to use separate batteries and regulators for the Jetson and other hardware is valid, especially considering the potential for power spikes or noise from the motors affecting the Jetson’s operation. Using separate power supplies could help isolate the Jetson from potential power quality issues related to the motors or other components. This approach would depend on your specific requirements, the available space and weight constraints of your rover, and the complexity you’re willing to introduce into your power supply system.
In summary, while the provided context does not recommend a specific 45-48W regulator module for the Jetson Orin Nano, it suggests that a well-regulated power supply is crucial. Using a reputable PDB with BEC like the Matek PDB FCHUB-12S V2 could be a viable option, but consider the potential benefits of isolating the power supply for the Jetson Orin Nano from other components to ensure reliable operation.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
5A@19V and 5A@12V should work for the Orin Nano 8GB to run at the MAXN_SUPER mode rated at 25W. The Jetson Orin Nano Developer Kit Carrier Board Specification includes the 9-20V spec for the DC jack.
I will have to defer to one of my software team counterparts about the setup in software for MAXN_SUPER only.
NVIDIA has only validated the power supply bundled with the Jetson Orin Nano Super Dev Kit so I cannot give any recommendations for power supplies in the 45-48W range.
For your 2 separate batteries question, the AI gave a good response for the topics to consider for your implementation.
