my program uses multi cuda video encoders(2,3,or more) to put its rendered image to multi h264 streams with different bitrate,the encoded image is read from OpenGL directly,I Create a CUDA context with "CU_CTX_SCHED_BLOCKING_SYNC " thread scheduling mode(just same as SDK’s sample),but from the doc’s description,this mode will block the OpenGL thread until encode task finished(I call “NVEncodeFrame()” API in OpenGL thread),this is a problem,especially to multi encoders,because my program generate image periodically,so all the tasks in OpenGL thread should be asynchronous then I can catch the best performance,but the “CU_CTX_SCHED_BLOCKING_SYNC” mode seems to breaking the rules, so which other mode should I use? AUTO,SPIN,or YIELD?
I had a other quesion: I found CudaEncAPI can set a cuctxLock to encoder object,so should I call “NVEncodeFrame()” in OpenGL thread,or a new thread?
