Which type of camera to use for Jetson Orin Nano Jetpack 7.2 RAW or YUV-i5?
Hello.
I have Nvidia Jetson Orin Nano Reference developer kit Super. With installed Jetpack 7.2 (and non-working jetson-io utility, so need to correct any io changes manually in FDT-Overlay config).
Now Im using inx219 or/and imx477. But for my purposes I need to use another sensor modules.
There are two different ones: IMX678(4K) MIPIYUV-i5 and IMX678(4K) MIPIRAW. They have the same sensor, but
RAW gets out RAW data (Bayer-pattern RAW10/12) and needs Argus nvarguscamerasrc proceeding. = MIPI (RAW)
YUV module gets out YUV-flow with pre-performed ISP (may be directly sent to v4l2src. MIPI (YUV)
So 2 paths with 2 different issues. 1) RAW needs BSP, device tree overlay + driver for sensor. 2) YUV needs BSP, device tree overlay + driver for ISP controller on sensor…
If the manufacturer provide drivers for sensor and for ISP controller, which way is better? How to fix FDT/overlay manually? or how to get jetson-io to work with it?
Who tried successfully to use imx678 cameras? which type you have chosen - RAW bayer modules or YUV modules?
Thanks!!
P.S. another theme is about RJ45 camera flow - how to manage it for AI recognition… but its later .
Please check the document to implement sensor driver for your sensor.
I would suggest using YUV sensor would have better performance.
