While install Jetpack with SDK Manager, I met a problem which the sdk manager can’t install python3.6-numpy package. So VPI on host missing dependencies error is occurred.
I tried to “retry” after installing python3-numpy but the SDK Manager keep trying install python3.6-numpy and dispayed error log.
Please check the log file exported from SDK Manager and give me some tips.
SDKM_logs_2022-10-11_20-07-50.zip (1.0 MB)
Based on the log, it seems the root cause is that python 3.6 cannot be installed.
17:48:14.742 - info: NV_VPI_HOST_COMP@host: The following packages have unmet dependencies:
17:48:14.791 - info: NV_VPI_HOST_COMP@host: python3-vpi1 : Depends: python3.6 but it is not installable
17:48:14.802 - info: Event: NV_VPI_HOST_COMP@host - error is: python3-vpi1 : Depends: python3.6 but it is not installable
17:48:14.803 - info: NV_VPI_HOST_COMP@host: Depends: python3.6-numpy but it is not installable
17:48:14.803 - info: Event: NV_VPI_HOST_COMP@host - error is: Depends: python3.6-numpy but it is not installable
17:48:14.823 - error: NV_VPI_HOST_COMP@host: E: Unable to correct problems, you have held broken packages.
17:48:14.823 - info: Event: NV_VPI_HOST_COMP@host - error is: E: Unable to correct problems, you have held broken packages.
Could you please share the environment of your host machine with us first?
Do you use Ubuntu 18.04?
My machine’s version of Ubuntu is 20.04 because my laptop is not compatible to Ubuntu18.04, Lenovo thinkpad x1 carbon :-(.
and I edited VERSION_ID item of /etc/os-release file from “20.04” to “18.04”, which I found this way from googling, searching keyword “how to install jetpack on Ubuntu 20.04”.
All step was okay except this.
Do I need to re-install OS with Ubuntu 18.04 or is there other way to resolve it?
I have just find that there is 20.04 version in the list of host os version for system requirement (NVIDIA SDK Manager | NVIDIA Developer)
Based on the package list in our apt server below, the packages for Ubuntu 20.04 are only available for the user of JetPack5.
https://repo.download.nvidia.com/jetson/#Jetpack%204.6
