While Predict Diffrent Value on Jetson TK1
I created my own model and uploaded it to the card. When I make prediction over and over for the same pictures, I get different predict results every time, even though I get the same results in the same picture.
How can I solve this problem?
Are you try to run deep learning model on the Jetson TK1?
If yes, could you share which frameworks do you use?
AFAIK, most of frameworks doesn’t support cuDNN v2 library now.
Yes, I install and run the deep learning model We created ourself.
Freme works is like bellow:
Cuda 6.5
Cudnn V2
Tensorflow 0.8.0
Keras=1.2.2
Numpy = 1.16
My model works fine on my pc and it returns correctly but on TK1 we take wrong results although there is no errors.
Which library do you use for reading input?
Some users found that the image format may be slightly different between ARM and desktop.
Could you check if you run the inference with the identical input first?
I use to opencv and numpy while read input.
Do you mind to check if there is any difference in the input between desktop and ARM system?
This happened to other users before since the packages are not identical.
