For example , there is a variable recording runtime since I pressed play button. After I pressed stop button it will reset to 0.
Hi @1031521414
You can subscribe to stage events and modify the variable according to the desired event
import carb.events
import omni.usd
# callback
def on_stage_event(event):
if event.type == int(omni.usd.StageEventType.SIMULATION_START_PLAY):
carb.log_info("SIMULATION_START_PLAY")
elif event.type == int(omni.usd.StageEventType.SIMULATION_STOP_PLAY):
carb.log_info("SIMULATION_STOP_PLAY")
# subscription
stage_event_sub = (omni.usd.get_context()
.get_stage_event_stream()
.create_subscription_to_pop(on_stage_event, name="subscription name"))
