White Screen when turn on kit
The last time I used this kit, it’s still working normally, but now when I turn on the kit, the fan running about 2 3 seconds and stop, the screen like this
I’m currently using this kit, so I don’t know much about it, but it that maybe the OS have some problems?
What is the exact model of this? Is it one which requires an SD card on the module itself? Or does it have eMMC (in which case the SD card would instead go on the carrier board). If this is an SD card model, then you probably need to reflash the QSPI (you could avoid flashing the SD card itself). If this is eMMC, then that same content is stored on eMMC partitions, and the best you could do is clone the rootfs to save it prior to a new flash. If you use any kind of other boot method, e.g., to an NVMe, then a lot changes. Before someone can answer though they will need the exact model and if you use any external boot media. The bottom line though is that the o/s is likely good, and only the earlier boot content is an issue (Jetsons don’t have a hardware BIOS, but everything a BIOS does is in software outside of the o/s itself).
thanks for your support, I try to setup OS again and it run normally
