Why 1D and 2D call config are not giving same results? check this code...
Paste the below code in template project in SDK samples and run it.
Basically the code is comparing the results of 1D and 2D call configs are same or not.
TestKernel1 uses 1D call config and TestKernel2 uses 2D call config.
But Both function results are NOT same.
[codebox]// // includes, system
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
// includes, project
#include <cutil_inline.h>
// includes, kernels
#include <template_kernel.cu>
global
void TestKernel1( int* array1, int limit )
int idx = __umul24(blockIdx.x,blockDim.x) + threadIdx.x;
if ( idx < limit )
	array1[idx] = idx;
global
void TestKernel2( int* array2, int limit )
int idy = __umul24(blockIdx.y,blockDim.y) + threadIdx.y;
int index = __umul24(idx,idy);
if ( index < limit )
	array2[index] = index;
// Program main
int
main( int argc, char** argv)
int* dArray1=NULL;
int* dArray2=NULL;
int width = 300;
int height = 200;
cudaMalloc( (void**)&dArray1, sizeof(int)*width*height );
cudaMalloc( (void**)&dArray2, sizeof(int)*width*height );
cudaMemset( dArray1, 0, sizeof(int)*width*height );
cudaMemset( dArray2, 0, sizeof(int)*width*height );
dim3 grid1( ((width*height)+255)/256,1,1);
dim3 block1( 256,1,1);
TestKernel1<<<grid1,block1>>>(dArray1, width*height);
dim3 grid2( (width+15)/16, (height+15)/16, 1);
dim3 block2( 16,16,1);
TestKernel2<<<grid2,block2>>>(dArray2, width*height);
int* hArray1=NULL;
int* hArray2=NULL;
hArray1 = (int*)malloc(sizeof(int)*width*height);
hArray2 = (int*)malloc(sizeof(int)*width*height);
cudaMemcpy( hArray1, dArray1, sizeof(int)*width*height, cudaMemcpyDeviceToHost);
cudaMemcpy( hArray2, dArray2, sizeof(int)*width*height, cudaMemcpyDeviceToHost);
int isSame = true;
for( int y = 0; y < height; ++y )
	for( int x = 0; x < width; ++x )
		int index = y*width+x;
		if( hArray1[index] != hArray2[index] )
			isSame = false;
if ( isSame == true )
	printf("\nBoth Kernels are same\n");
else
	printf("\nBoth Kernels are NOT same\n");
free(hArray1);
free(hArray2);
cudaFree(dArray1);
cudaFree(dArray2);
cutilExit(argc, argv);
[/codebox]
Makes sense, looks like your indexing is wrong in the 2D case. Here’s my edited code which runs correctly.
[codebox]
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
global
if ( idx < limit )
array1[idx] = idx;
global
void TestKernel2( int* array2, int w, int h )
int index = __umul24(w,idy)+idx;
if ((idx < w) & (idy < h))
// Program main
int
int* dArray1=NULL;
int* dArray2=NULL;
int width = 300;
int height = 200;
cudaMalloc( (void**)&dArray1, sizeof(int)widthheight );
cudaMalloc( (void**)&dArray2, sizeof(int)widthheight );
cudaMemset( dArray1, 0, sizeof(int)widthheight );
cudaMemset( dArray2, 0, sizeof(int)widthheight );
TestKernel2<<<grid2,block2>>>(dArray2, width,height);
int* hArray1=NULL;
int* hArray2=NULL;
hArray1 = (int*)malloc(sizeof(int)widthheight);
hArray2 = (int*)malloc(sizeof(int)widthheight);
cudaMemcpy( hArray1, dArray1, sizeof(int)widthheight, cudaMemcpyDeviceToHost);
cudaMemcpy( hArray2, dArray2, sizeof(int)widthheight, cudaMemcpyDeviceToHost);
int isSame = true;
isSame = false;
printf(“\nBoth Kernels are same\n”);
else
printf(“\nBoth Kernels are NOT same\n”);
free(hArray1);
free(hArray2);
cudaFree(dArray1);
cudaFree(dArray2);
[/codebox]
N.
@ Nico,
thanks Nico, yes indexing in2D call config is wrong.
We can use the below code as well…
[codebox]void TestKernel2( int* array2, int limit, int width )
int index = __umul24(idy,width)+idx;
}[/codebox]
You could use that code, but then you’d be writing some values twice unless your width is a multiple of 16.
You’ve got a grid of (19,13) blocks, with (16,16) threads each so for example
Thread (12,0) of block (18,0) will write to:
idx = (1816)+12 = 300
idy = 0
index = 0
300+300 = 300
And thread (0,1) of block (0,0) will also write to:
idx = (016)+0 = 0
idy = 1
index = 1
300+0 = 300
N.
Yes, you are correct. writing twice into the same mem location is bad.
but when I run your code, the timings are…
TestKernel1 exe time: 0.038467
TestKernel2 exe time: 0.032263
Press ENTER to exit…
When I run the second version of My TestKernel2(), then timings are…
TestKernel1 exe time: 0.039194
TestKernel2 exe time: 0.027828
True, it’ll be a bit slower because of the extra if test that needs to be performed. All I’m saying is that you will run into trouble when you’re writing code that generates values based on the contents of threadID and/or blockID. In that case, it’ll write out two different values to the same location and the result will depend on which thread accesses it last.
N.
yes, you are 100% right. Thanks.
