Why are CuNumeric's Discrete Fourier Transform functions slower than Numpy's?
I am trying to compare the performance of fft2 in numpy and cunumeric.
import numpy as np
import time
import matplotlib.pyplot as plt
def run_fft_with_timing(matrix_size):
    # Generate a random array for testing
    array_size = (matrix_size, matrix_size)
    test_array = np.random.rand(*array_size)
    # Measure execution time of np.fft.fft2
    start_time = time.time()
    result = np.fft.fft2(test_array)
    end_time = time.time()
    execution_time = end_time - start_time
    return execution_time
# List of matrix sizes to test
matrix_sizes = [10, 50, 100, 200, 500, 1000, 1500, 2000, 3000]
# Run FFT with timing for each matrix size
execution_times = [run_fft_with_timing(size) for size in matrix_sizes]
# Plotting
plt.plot(matrix_sizes, execution_times, marker='o', linestyle='-',label='Numpy')
import cunumeric as np
# Run FFT with timing for each matrix size for cunumeric
# Plotting
plt.plot(matrix_sizes, execution_times, marker='o', linestyle='-',label='CuNumeric')
plt.title('Execution Time vs Matrix Size')
plt.xlabel('Matrix Size')
plt.ylabel('Execution Time (seconds)')
plt.grid(True)
plt.legend()
plt.show()
After a quick glance at the code, I’m pretty sure you’re timing the data transfer to and from the GPU. I highly suggest you take our core on “Fundamentals of Accelerated Computing” to understand what’s going on. Courses – NVIDIA
