Why are IB Interfaces are running at 20gbps with Unexpected actual link speed 5
TLDR: How do I resolve this error:
Unexpected actual link speed 5 (enable_speed1=“2.5 or 5 or 10”, enable_speed2=“2.5 or 5 or 10” therefore final speed should be 10)
I am not sure if I am missing a step somewhere, but the fabric works just with very high ping times
C:> ibdiagnet
Speed / Width checks
-I- Link Speed Check (Compare to supported link speed)
-E- Links Speed Check finished with errors
-E- Link: S24be05ffffcb19e3/N24be05ffffcb19e0(ECHO2)/P1<–>Sf4521403002220f0/Nf4521403002220f0(SwitchX - Mellanox Technologies)/P3 - Unexpected actual link speed 5 (enable_speed1=“2.5 or 5 or 10”, enable_speed2=“2.5 or 5 or 10” therefore final speed should be 10)
-E- Link: Sf4521403002220f0/Nf4521403002220f0(SwitchX - Mellanox Technologies)/P1<–>S24be05ffffcbb733/N24be05ffffcbb730(ECHOHCTL)/P1 - Unexpected actual link speed 5 (enable_speed1=“2.5 or 5 or 10”, enable_speed2=“2.5 or 5 or 10” therefore final speed should be 10)
-E- Link: Sf4521403002220f0/Nf4521403002220f0(SwitchX - Mellanox Technologies)/P2<–>S24be05ffffaa8853/N24be05ffffaa8850(ECHO1)/P1 - Unexpected actual link speed 5 (enable_speed1=“2.5 or 5 or 10”, enable_speed2=“2.5 or 5 or 10” therefore final speed should be 10)
-I- Link Width Check (Compare to supported link width)
-I- Links Width Check finished successfully
Cable Diagnostic (Plugin)
-I- Cable Info retrieving finished successfully
Summary
-I- Stage Warnings Errors Comment
-I- Discovery 0 0
-I- Lids Check 0 0
-I- Links Check 0 0
-I- Subnet Manager 0 0
-I- Port Counters 0 0
-I- Nodes Information 0 0
-I- Speed / Width checks 0 3
-I- Partition Keys 0 0
-I- Alias GUIDs 0 0
-I- Cable Diagnostic (Plugin) 0 0
C:> ibstat
CA ‘ibv_device0’
CA type:
Number of ports: 2
Firmware version: 2.40.5030
Hardware version: 0x0
Node GUID: 0x24be05ffffcbb730
System image GUID: 0x24be05ffffcbb733
Port 1:
State: Active
Physical state: LinkUp
Rate: 20
Base lid: 6
LMC: 0
SM lid: 6
Capability mask: 0x90580000
Port GUID: 0x24be05ffffcbb731
Link layer: IB
Transport: IB
Port 2:
State: Down
Physical state: Polling
Rate: 40
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0x24be05ffffcbb732
Link layer: IB
Transport: IB
CA ‘ibv_device0’
CA type:
Number of ports: 2
Node GUID: 0x24be05ffffaa8850
System image GUID: 0x24be05ffffaa8853
Port 1:
State: Active
Rate: 20
Base lid: 5
LMC: 0
SM lid: 6
Port GUID: 0x24be05ffffaa8851
Link layer: IB
Transport: IB
Port 2:
State: Down
Rate: 40
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0x24be05ffffaa8852
Link layer: IB
Transport: IB
CA ‘ibv_device0’
CA type:
Number of ports: 2
Node GUID: 0x24be05ffffcb19e0
System image GUID: 0x24be05ffffcb19e3
Port 1:
State: Active
Rate: 20
Base lid: 7
LMC: 0
SM lid: 6
Port GUID: 0x24be05ffffcb19e1
Link layer: IB
Transport: IB
Port 2:
State: Down
Rate: 40
Base lid: 0
LMC: 0
SM lid: 0
Port GUID: 0x24be05ffffcb19e2
Link layer: IB
Transport: IB
C:>ibnetdiscover
Topology file: generated on Fri Sep 29 11:29:00 2017
Initiated from node 24be05ffffaa8850 port 24be05ffffaa8851
vendid=0x2c9
devid=0xc738
sysimgguid=0xf4521403002220f0
switchguid=0xf4521403002220f0(f4521403002220f0)
Switch 18 “S-f4521403002220f0” # “SwitchX - Mellanox Technologies” base port 0 lid 2 lmc 0
[1] "H-24be05ffffcbb730"1 # “ECHOHCTL” lid 6 4xDDR
[2] "H-24be05ffffaa8850"1 # “ECHO1” lid 5 4xDDR
[3] "H-24be05ffffcb19e0"1 # “ECHO2” lid 7 4xDDR
vendid=0x2c9
devid=0x1003
sysimgguid=0x24be05ffffcb19e3
caguid=0x24be05ffffcb19e0
Ca 2 “H-24be05ffffcb19e0” # “ECHO2”
1 “S-f4521403002220f0”[3] # lid 7 lmc 0 “SwitchX - Mellanox Technologies” lid 2 4xDDR
vendid=0x2c9
devid=0x1003
sysimgguid=0x24be05ffffcbb733
caguid=0x24be05ffffcbb730
Ca 2 “H-24be05ffffcbb730” # “ECHOHCTL”
1 “S-f4521403002220f0”[1] # lid 6 lmc 0 “SwitchX - Mellanox Technologies” lid 2 4xDDR
vendid=0x2c9
devid=0x1003
sysimgguid=0x24be05ffffaa8853
caguid=0x24be05ffffaa8850
Ca 2 “H-24be05ffffaa8850” # “ECHO1”
1 “S-f4521403002220f0”[2] # lid 5 lmc 0 “SwitchX - Mellanox Technologies” lid 2 4xDDR
C:>ibping -L 6
Pong from ?hostname?.?domainname? (Lid 6): time 0.214 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.118 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.101 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.099 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.122 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.102 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.132 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.104 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.125 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.111 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.093 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.092 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.108 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.115 ms
Pong from ?hostname?.?domainname? (Lid 6): time 0.123 ms
— ?hostname?.?domainname? (Lid 6) ibping statistics —
17 packets transmitted, 17 received, 0% packet loss, time 18548 ms
rtt min/avg/max = 0.092/0.115/0.214 ms
Thank you Marlon,
Is there a way to test which cable or do all of them have to be replaced?
Best to just replace the cables.
Hi Jaime,
This is an indication of a faulty cable.
You can try to reseat the cable, however the cable may need to be replaced.
