I’m using the LightBeam-Sensor in 4.5 and noticed that an invisible object is still triggering the sensor.
In my simulation I’d like to fake the grasping of an item off of the conveyor by making it invisible, but this approach does not work.
Related topics
Topic | Replies | Views | Activity | |
Is it possible to point/follow to something with lightbeam sensors? | 1 | 15 | February 14, 2025 | |
Isaac contact example can't sense deformable object | 3 | 525 | May 10, 2023 | |
Applying visual material to contact sensor | 2 | 1004 | November 24, 2023 | |
Want to add visual to LiDAR | 0 | 28 | November 5, 2024 | |
Toggling visibility + recorder memory leak | 2 | 412 | April 5, 2024 | |
How to add transparent visual materials in Isaac Sim? | 1 | 1313 | April 17, 2023 | |
Display and Blank objects within Omniverse Sequencer | 9 | 433 | March 11, 2024 | |
Rigid bodies with collision properties are not visible | 0 | 29 | December 14, 2024 | |
Lidar can't detected moving people | 3 | 460 | May 16, 2023 | |
Conveyor Belt Moving, but Object Not Following - Help Needed | 3 | 61 | November 1, 2024 |
