I am trying to apply a TF transformation using “ROS1 Publish Raw Transform Tree” but the rotation input is grayed out (translation is not). I also noticed inputs for components “Constant Quatf” and “Constant Quatd” are grayed out. Is this intentional? If so, how can I perform a TF rotation then between two frames?
Related topics
Topic | Replies | Views | Activity | |
ROS1 Publish Transform Tree Denormalized Quaternion Issue in Version 2023.1.1 | 7 | 461 | May 19, 2025 | |
TF tree error isaac sim 4.5.0 | 2 | 39 | March 26, 2025 | |
Exclude parts of the transform tree being published? | 0 | 140 | April 20, 2024 | |
External Extensions: Display the tf transformation tree | 1 | 601 | April 5, 2024 | |
Prim is not an articulation in ROS2 Publish Joint States | 2 | 34 | April 7, 2025 | |
Difference transform in ROS tf and Isaac stage | 0 | 175 | April 29, 2024 | |
[Bug] ROS2 Publishers don't work in Compound Subgraph if the subgraph has inputs | 0 | 21 | September 6, 2024 | |
Transformation change on non-root links is not supported | 5 | 1480 | February 18, 2022 | |
Error when using ROS2PublishJointState: Prim is not an articulation | 2 | 51 | February 18, 2025 | |
Surprising orientation of April Tag Texture | 2 | 48 | December 19, 2024 |
