In the kernel bootlog I can see this message initially.
[ 0.511302] as3722 4-0040: AS3722 with revision 0x1 found
[ 0.516143] as3722_sd0: 700 <–> 1300 mV at 1000 mV 3500 mA normal standby
[ 0.517233] as3722_sd1: 700 <–> 1350 mV at 1150 mV 2500 mA normal standby
[ 0.517586] as3722_sd2: 1350 mV normal standby
[ 0.517897] as3722-sd3: no parameters
[ 0.518337] as3722_sd4: 1050 mV normal standby
[ 0.518960] as3722_sd5: 1800 mV normal standby
[ 0.519424] as3722_sd6: applied init 1000000uV constraint
[ 0.520011] as3722_sd6: 650 <–> 1200 mV at 1000 mV 3500 mA normal standby
[ 0.520342] as3722_ldo0: 1050 <–> 1225 mV at 1050 mV at 300 mA normal standby
[ 0.520394] as3722_ldo0: supplied by as3722_sd2
[ 0.521830] as3722_ldo1: 1800 mV at 150 mA normal standby
[ 0.522676] as3722_ldo2: 1200 mV at 150 mA normal standby
[ 0.522725] as3722_ldo2: supplied by as3722_sd5
[ 0.523708] as3722_ldo3: 800 mV at 150 mA normal standby
[ 0.524164] as3722_ldo4: 2700 mV at 150 mA normal standby
[ 0.524615] as3722_ldo5: 1200 mV at 150 mA normal standby
[ 0.524665] as3722_ldo5: supplied by as3722_sd5
[ 0.525005] as3722_ldo6: 1800 <–> 3300 mV at 150 mA normal standby
[ 0.525470] as3722_ldo7: 1050 mV at 150 mA normal standby
[ 0.525520] as3722_ldo7: supplied by as3722_sd5
[ 0.526640] as3722_ldo9: 3300 mV at 150 mA normal standby
[ 0.527095] as3722_ldo10: 2700 mV at 150 mA normal standby
[ 0.527575] as3722_ldo11: 1800 mV at 150 mA normal standby
But after a few seconds they get disabled.
[ 5.072489] Disabling clocks left on by bootloader:
[ 5.072492] audio_2x
[ 5.072504] audio
[ 5.072509] audio4
[ 5.072513] audio3
[ 5.072518] audio2
[ 5.072522] audio1
[ 5.072526] audio0
[ 5.072637] hdmi_audio
[ 5.072644] entropy
[ 5.072658] dsi2-fixed
[ 5.072662] dsi1-fixed
[ 5.072689] trace
[ 5.072699] bsev
[ 5.072757] cclk_lp
[ 5.072767] pll_x_out0
[ 5.072771] pll_u_12M
[ 5.072790] pll_m_out1
[ 5.074112] tegra_dvfs: registered vdd_cpu simon notifier
[ 5.074724] Tegra CPU DFLL is initialized with use_dfll = 1
[ 5.074997] CPU rate: 696 MHz
[ 5.077775] cpu_cold cooling device is registered
[ 5.079033] cpu_hot cooling device is registered
[ 5.336140] tegra dvfs: tegra sysfs cap interface is initialized
[ 5.336304] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 5.336311] tegra dvfs: registered vdd_gpu simon notifier
[ 5.336703] tegra_actmon.emc: Completed initialization (0)
[ 5.337086] tegra_actmon.avp: Completed initialization (0)
[ 5.337333] tegra_mon.cpu_emc: Completed initialization (0)
[ 5.340246] as3722_ldo11: disabling
[ 5.340425] as3722_ldo10: disabling
[ 5.340586] as3722_ldo9: disabling
[ 5.340747] as3722_ldo7: disabling
[ 5.340907] as3722_ldo5: disabling
[ 5.341066] as3722_ldo4: disabling
[ 5.341256] as3722_ldo1: disabling
[ 5.341423] as3722-sd3: disabling
Is this happening for anybody else? Why does this behavior occur? How do I make sure that all these LDOs stay enabled during boot (or atleast LDO1)? Could somebody explain please.
