I wrote code like this:
float* ComparisonList;
cudaMalloc((void**)&ComparisonList, sizeof(float)* Times * row * IndexNum);
ConstantFalseAlarmRate << <GridForConstantFalseAlarmRate, ThreadsPerBlock >> > (NormallizeData, ComparisonList, StartIndex, EndIndex, ExerciseUnit, ProtectUnit, alpha, row, col, Times);
__global__ void ConstantFalseAlarmRate(float* InputData, float* OutputData, int StartIndex, int EndIndex, int ExerciseUnit, int ProtectUnit, float alpha, int row, int col, int Times)
int i = threadIdx.x + blockDim.x * blockIdx.x;
int j = threadIdx.y + blockDim.y * blockIdx.y;
int k = threadIdx.z + blockDim.z * blockDim.z;
if (i < 110 && j < row && k < Times)
OutputData[k * row * 110 + j * 110 + i] = 0.1;
I am sure that the input is correct, and the blocksize and gridsize is (64,8,2), (2,16,50), row = 128, Times =100, IndexNum = 110.
It turns out that i could only assign some value to “ComparisonList”, that is , just a few of elements in “ComparisonList” are 0.1, others are “0”.
It’s weird, because i didn’t assign “0” to “ComparisonList”. That means at least values in “ComparisonList” should be “NAN”, but they are “0”.
I don’t know why would this happen. Can you give me some advice to deal with this bug?
