I was going to configure the 40pin SPI function, but when I ran sudo /opt/nvidia/jetson-io/jetson-io.py, I entered the configuration screen, but it immediately dropped out, so I couldn’t configure the pin function. When I run sudo /opt/nvidia/jetson-io/config-by-pin.py check the pin command. The following error is displayed:
File “/opt/nvidia/jetson-io/config-by-pin.py”, line 84, in
main()
File “/opt/nvidia/jetson-io/config-by-pin.py”, line 43, in main
raise RuntimeError(“Platform not supported, no headers found!”)
RuntimeError: Platform not supported, no headers found!
The board model I use is:Jetson xavier nx.
