Why can't we reuse the same source-id after stream reach EOS
• Hardware Platform (Jetson / GPU) Jetson xavier
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1-b147
• TensorRT Version 8.5
In my pipeline when a input stream reaches EOS i will deleted , When I add a new input stream with the same ID as the already deleted EOS input it fails . But if I use a different ID from the one that reaches EOS it can work very well . Can you explain me why such a behavior and how to overcome this issue because I need to keep the same ID.
How did you delete and add the source?
I have used the same method like the one here https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/apps/runtime_source_add_delete
Hi any feedback ?
