Why custom label is not displayed?
• Hardware Platform (Jetson / GPU) RTX4080
• DeepStream Version 7.0
Trying to display custom label on display.
I have added the following lines of codes in the tiler_sink_pad_buffer_probe.
I like to display label msg_meta.objClassId = 14. According to label file, classID 14 is stand. But sand is not displayed.
The whole code is as follows.
def tiler_sink_pad_buffer_probe(pad, info, u_data):
    global CameraWidgets
    frame_number = 0
    num_rects = 0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
        except StopIteration:
            break
        frame_number = frame_meta.frame_num
        n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
        # convert python array into numpy array format in the copy mode.
        frame_copy = np.array(n_frame, copy=True, order='C')
        # convert the array into cv2 default color format
        frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGR)
        CameraWidgets[frame_meta.pad_index].set_frame(frame_copy)
        if platform_info.is_integrated_gpu(): # If Jetson, since the buffer is mapped to CPU for retrieval, it must also be unmapped
            pyds.unmap_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id) # The unmap call should be made after operations with the original array are complete.
        #  The original array cannot be accessed after this call.
        l_obj = frame_meta.obj_meta_list
        while l_obj is not None:
                try:
                    obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                    continue
                user_event_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta)
                if user_event_meta:
                    msg_meta = pyds.alloc_nvds_event_msg_meta(user_event_meta)
                    msg_meta.bbox.top = obj_meta.rect_params.top-20
                    msg_meta.bbox.left = obj_meta.rect_params.left
                    msg_meta.bbox.width = obj_meta.rect_params.width
                    msg_meta.bbox.height = obj_meta.rect_params.height
                    user_event_meta.user_meta_data = msg_meta
                    user_event_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
                    pyds.nvds_add_user_meta_to_frame(frame_meta, user_event_meta)
                try:
                    l_obj = l_obj.next
                    break
        global perf_data
        stream_index = "stream{0}".format(frame_meta.pad_index)
        perf_data.update_fps(stream_index)
        try:
            l_frame = l_frame.next
            break
    return Gst.PadProbeReturn.OK
Label file is attached.
labels_peoplenet.txt (993 Bytes)
Config file also have change at
dstest_imagedata_config.txt (2.0 KB)
You can refer to our source code deepstream_test_1.py. If you want to customize what display on the screen, you need to use the display_meta.
Is it possible to turn off pgie label display and just display custom display, can?
For custom display, I can follow deepstream_test_1.py.
If i set flag display-text to 0, all both (pgie and custom) won’t be displayed, right?
How can I turn off pgie label and show custom label only?
I have modified code as follows. But display not come out yet.
display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
py_nvosd_text_params = display_meta.text_params[0]
py_nvosd_text_params.display_text = 'test'#d_ret[b_i]['labels'][0]
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10#int(obj_meta.rect_params.left)
py_nvosd_text_params.y_offset = 20#int(obj_meta.rect_params.top-50)
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 20
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
 # set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 1.0, 0.0, 1.0)
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
    frame_number = 0
    num_rects = 0
    if not gst_buffer:
        return
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
            break
        time.sleep(0.002)
        d_ret = objects_metainfo.retrieve(frame_meta.pad_index)
        if len(d_ret) > 0:
            #print("camera idx " + str(frame_meta.pad_index))
            #print(d_ret)
                try:
                    continue
                for b_i in range(len(d_ret)):
                    #print(d_ret[b_i]['labels'])
                    boxA = [d_ret[b_i]['box'][0][0], d_ret[b_i]['box'][0][1], d_ret[b_i]['box'][1][0], d_ret[b_i]['box'][1][1]]
                    boxB = [obj_meta.rect_params.left, obj_meta.rect_params.top, obj_meta.rect_params.left+obj_meta.rect_params.width, obj_meta.rect_params.top+obj_meta.rect_params.height]
                    xA = max(boxA[0], boxB[0])
                    yA = max(boxA[1], boxB[1])
                    xB = min(boxA[2], boxB[2])
                    yB = min(boxA[3], boxB[3])
                    # compute the area of intersection rectangle
                    interArea = abs(max((xB - xA, 0)) * max((yB - yA), 0))
                    if interArea == 0:
                        return 0
                    # compute the area of both the prediction and ground-truth
                    # rectangles
                    boxAArea = abs((boxA[2] - boxA[0]) * (boxA[3] - boxA[1]))
                    boxBArea = abs((boxB[2] - boxB[0]) * (boxB[3] - boxB[1]))
                    # compute the intersection over union by taking the intersection
                    # area and dividing it by the sum of prediction + ground-truth
                    # areas - the interesection area
                    iou = interArea / float(boxAArea + boxBArea - interArea)
                    if iou > 0.0:
                    #print(boxA)
                    #print(boxB)
                    #print(iou)
                try:
                    l_obj = l_obj.next
                    break
        global perf_data
        try:
            break
Yes.
You can try deleting the contents of your label config file.
The following code supposed to display text at fixed position in display. But it didn’t.
    frame_number = 0
    num_rects = 0
    if not gst_buffer:
        return
        try:
            # it alone.
            break
                try:
                    continue
                display_meta.num_labels = 1
                try:
                    l_obj = l_obj.next
                    break
        global perf_data
        try:
            break
I am going to display on every object inside the frame with custom display. Is display_meta the right meta to use?
Yes. Could you attach your whole piepline and the position where the probe function you added?
I found problem in my code. Thanks
