(launcher) xgy@xgy:~$ tao detectnet_v2 train --help
2021-09-08 14:36:21,791 [INFO] root: Registry: [‘nvcr.io’]
2021-09-08 14:36:21,882 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/xgy/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
2021-09-08 14:36:23,290 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
~/.tao_mounts.json wasn’t found. Falling back to obtain mount points and docker configs from ~/.tlt_mounts.json.
Please note that this will be deprecated going forward.
2021-09-08 14:57:15,369 [INFO] root: Registry: [‘nvcr.io’]
2021-09-08 14:57:19,576 [WARNING] tlt.components.docker_handler.docker_handler:
DockerOptions portion of the “/home/morganh/.tlt_mounts.json” file. You can obtain your
terminal.
Using TensorFlow backend.
usage: detectnet_v2 train [-h] [–num_processes NUM_PROCESSES] [–gpus GPUS]
[–gpu_index GPU_INDEX [GPU_INDEX …]] [–use_amp]
[–log_file LOG_FILE] [-e EXPERIMENT_SPEC_FILE]
[-r RESULTS_DIR] [-n MODEL_NAME] [-v] -k KEY
{calibration_tensorfile,dataset_convert,evaluate,export,inference,prune,train}
optional arguments:
-h, --help show this help message and exit
–num_processes NUM_PROCESSES, -np NUM_PROCESSES
The number of horovod child processes to be spawned.
Default is -1(equal to --gpus).
–gpus GPUS The number of GPUs to be used for the job.
The indices of the GPU’s to be used.
–use_amp Flag to enable Auto Mixed Precision.
–log_file LOG_FILE Path to the output log file.
-e EXPERIMENT_SPEC_FILE, --experiment_spec_file EXPERIMENT_SPEC_FILE
Path to spec file. Absolute path or relative to
working directory. If not specified, default spec from
spec_loader.py is used.
-r RESULTS_DIR, --results_dir RESULTS_DIR
Path to a folder where experiment outputs should be
written.
-n MODEL_NAME, --model_name MODEL_NAME
Name of the model file. If not given, then defaults to
model.hdf5.
-v, --verbose Set verbosity level for the logger.
-k KEY, --key KEY The key to load pretrained weights and save
intermediate snapshopts and final model.
Seems that your cpu is a bit old. What is the cpu info ?
More, please search “Illegal instruction” in Tao forum. Previously some users get the same issues. Unfortunately TAO does not support it.
but it can work well in conversational AI
(launcher) xgy@xgy:~$ tao text_classification dataset_convert -h
2021-09-08 15:08:41,843 [INFO] root: Registry: [‘nvcr.io’]
2021-09-08 15:08:41,929 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
[NeMo W 2021-09-08 07:08:46 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
INFO: Generating new fontManager, this may take some time…
usage: text_classification [-h] -r RESULTS_DIR [-k KEY] [-e EXPERIMENT_SPEC_FILE] [-g GPUS] [-m RESUME_MODEL_WEIGHTS] [-o OUTPUT_SPECS_DIR]
{dataset_convert,evaluate,export,finetune,infer,infer_onnx,train,download_specs}
Train Adapt Optimize Toolkit
positional arguments:
Subtask for a given task/model.
optional arguments:
Path to a folder where the experiment outputs should be written. (DEFAULT: ./)
-k KEY, --key KEY User specific encoding key to save or load a .tlt model.
Path to the experiment spec file.
-g GPUS, --gpus GPUS Number of GPUs to use. The default value is 1.
-m RESUME_MODEL_WEIGHTS, --resume_model_weights RESUME_MODEL_WEIGHTS
Path to a pre-trained model or model to continue training.
-o OUTPUT_SPECS_DIR, --output_specs_dir OUTPUT_SPECS_DIR
Path to a target folder where experiment spec files will be downloaded.
2021-09-08 15:08:47,234 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
My environment is virtual by proxmox,it can use? the cpu info
xgy@xgy:/data/xgy/worksapce/tao/cv_samples_v1.2.0$ cat /proc/cpuinfo | grep name | cut -f2 -d: | uniq -c
16 Common KVM processor
