Docker images of deepstream-l4t: 6.1.1-triton, under jetson Xavier NX with corresponding version as shown below:
I have setup the environment and run the code successfully as per official command. But when I reduce the source from 4 to 1 in the source.csv file, and found the program block without any error report.
I used two models with the following configuration files as below, and I just remove two source urls in the csc file without any change in other configuration files. I’m not clear if any setting need to be revised accordingly ? config_infer_primary.txt (556 Bytes) config_infer_primary(1).txt (556 Bytes)
