sudo /opt/nvidia/jetson-io/jeston-io.py
This is the 64GB sd card option.
Same results with NVMe install using sdkmanager
This did work the other day and now after fresh install its spawns then closes immediately.
I deleted the first sdkmanager and started over to make sure I was not the one that broke this. With the fresh sdkmanager install at 1.5 mbs download rate that takes forever it no longer will launch.
What is up with this, you cannot blame me for messing around with this. OUT OF THE BOX, first thing I did was open a terminal and try to use it. VERY FIRST task and its broken.
Update:
Here is part of the problem the board.py is missing.
>>> from Jetson import board
File "<stdin>", line 1, in <module>
ImportError: cannot import name 'board' from 'Jetson' (/usr/lib/python3/dist-packages/Jetson/__init__.py)
fred@orin1:~$ python3 -c "import Jetson; print(Jetson.__file__)"
fred@orin1:~$ ls /usr/lib/python3/dist-packages/Jetson/
GPIO __init__.py
fred@orin1:~$
fred@orin1:/opt/nvidia/jetson-io$ cat jetson-io.py
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2019-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: MIT
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
from curses import panel
import curses
import os
import shutil
import sys
import textwrap
class Window(object):
def __init__(self, screen, h, w, y, x):
self.h = h
self.w = w
self.win = curses.newwin(h, w, y, x)
self.panel = panel.new_panel(self.win)
self.win.clear()
self.panel.hide()
panel.update_panels()
def clear(self):
self.win.clear()
It is in the sdk rootfs, its not being installed.
fred@eng-ai1:~/yocto/nvidia-sdkmanager/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra$ sudo find . -name board.py
[sudo] password for fred:
./rootfs/opt/nvidia/jetson-io/Jetson/board.py
copied it over and it has more missing files.
fred@orin1:~$ python3 -c "from Jetson import board; print('board.py imported successfully')"
File "<string>", line 1, in <module>
File "/usr/lib/python3/dist-packages/Jetson/board.py", line 22, in <module>
from Linux import dt
ModuleNotFoundError: No module named 'Linux'
fred@orin1:~$
