Unfortunately, the provided context does not explicitly state why NVIDIA decided to use a non-standard 6.57mm standoff height for the Orin NX. However, I can provide some insights and comparisons that might be helpful.
The Jetson Orin NX series, as well as other Jetson modules, are designed to be compact and versatile, allowing for a wide range of applications and use cases. The choice of standoff height might be influenced by various factors, such as:
- Mechanical design constraints: The Orin NX module’s dimensions, shape, and layout might require a specific standoff height to ensure proper clearance, thermal management, or structural integrity.
- Electrical and signal integrity considerations: The standoff height might be chosen to optimize signal integrity, reduce electromagnetic interference (EMI), or ensure reliable connections between the module and the carrier board.
- Manufacturing and assembly processes: The use of a non-standard standoff height might be driven by manufacturing or assembly requirements, such as the need for a specific type of connector or the use of a particular manufacturing process.
In comparison, the SMARC (Smart Mobility ARChitecture) standard, which uses SODIMM connectors with even number value standoffs (e.g., 3mm, 5mm), is a different design approach. SMARC is a standardized form factor for computer-on-modules (COMs), which aims to provide a common interface and mechanical compatibility across different modules and carrier boards.
While the SMARC standard uses more conventional standoff heights, the Jetson Orin NX series might have specific design requirements that necessitate a non-standard standoff height. It’s possible that NVIDIA’s design team chose the 6.57mm standoff height to address specific technical challenges or to optimize the module’s performance, thermal management, or mechanical reliability.
In the absence of an explicit statement from NVIDIA, it’s difficult to provide a definitive answer. However, it’s worth noting that the use of non-standard standoff heights is not uncommon in the electronics industry, and manufacturers often make design choices based on specific technical requirements or constraints.
If you’re looking for a solution to work with the 6.57mm standoff height, you’ve already found some 6.5mm standoffs, which might be a suitable alternative. You may also want to consider consulting with NVIDIA’s technical support or a mechanical engineering expert to better understand the design considerations behind the Orin NX module’s standoff height.
