root@L087:/usr/src/jetpack/64_TX2/Linux_for_Tegra_tx2# (time sudo ./flash.sh --no-flash smartsense-1 mmcblk0p1) 2>&1 | tee sources/flash.output
./tegraflash.py --chip 0x18 --applet "/usr/src/jetpack/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin" --cmd "dump eeprom boardinfo cvm.bin" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0022 ] Generating RCM messages
[ 0.0032 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /usr/src/jetpack/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0041 ] RCM 0 is saved as rcm_0.rcm
[ 0.0046 ] RCM 1 is saved as rcm_1.rcm
[ 0.0046 ] List of rcm files are saved in rcm_list.xml
[ 0.0046 ]
[ 0.0046 ] Signing RCM messages
[ 0.0057 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0067 ] Assuming zero filled SBK key
[ 0.0105 ]
[ 0.0105 ] Copying signature to RCM mesages
[ 0.0130 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0158 ]
[ 0.0159 ] Boot Rom communication
[ 0.0168 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.5062 ]
Error: Return value 8
Command tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
Reading board information failed.
My sequence is:
- flash.sh --no-flash to create the system image, etc
- build docker image
- later on…
- run docker image with ENTRYPOINT=‘sudo flash.sh -r jetson-tx2 mmcblk0p1’
Why does the initial run with --no-flash require a TX2 in recovery mode?
