I’m using a Jetson Nano with a Raspberry Pi camera module. If I don’t explicitly specify a framerate then nvarguscamerasrc reports a framerate of 30/1 rather than the actual framerate:
$ gst-launch-1.0 -v nvarguscamerasrc num-buffers=60 \
! 'video/x-raw(memory:NVMM), width=3280, height=2464' \
! fakesink
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps =
width=(int)3280, height=(int)2464,
format=(string)NV12,
framerate=(fraction)30/1
GST_ARGUS: Running with following settings:
Output Stream W = 3280 H = 2464
Frame Rate = 21.000000
So above we can see that it knows that Frame Rate = 21
however it fills in framerate=(fraction)30/1
and this is what’s seen by everything downstream in the pipeline.
If I specify an incorrect framerate then this is neither corrected nor does it result in an error:
! 'video/x-raw(memory:NVMM), width=3280, height=2464, framerate=120/1' \
! fakesink
framerate=(fraction)120/1
Here I specified 120/1 and even though it can only capture at 21/1 at this width and height it doesn’t complain - it captures at 21/1 but reports 120/1 downstream in the pipeline.
This is a little frustrating - I don’t want to worry about the framerate and I’m happy to let the camera chose the rate, e.g. 21/1 above, but I want the actual rate reported in the pipeline rather than an incorrect default of 30/1 (if I don’t specify a framerate) or an incorrect rate if I specify an invalid framerate and the camera chooses a different one.
I can confirm that the incorrect framerate makes it all the way down the pipeline and is stored in any resulting video file:
$ gst-launch-1.0 -v nvarguscamerasrc \
! nvjpegenc \
! matroskamux \
! filesink location=out.mkv
$ ffprobe -loglevel panic -show_streams out.mkv | fgrep r_frame_rate
r_frame_rate=30/1
Here Frame Rate = 21
but r_frame_rate=30/1
is reported for the resulting MKV file.
Is there any way to tell nvarguscamerasrc to report the actual framerate to the pipeline?
