The following test code compiles with all of our known compilers except PGI (version 7 through 10.6 tried):
$ cat SimpleTestAbsBug.cc
/* abs example */
#include <stdlib.h>
#include
int main ()
double ATOL;
double VL;
VL = 9.9999999;
ATOL = abs(VL);
return 0;
$ CC -c SimpleTestAbsBug.cc
“SimpleTestAbsBug.cc”, line 10: error: more than one instance of overloaded
function “abs” matches the argument list:
function “abs(int)”
function “std::abs(long)”
argument types are: (double)
ATOL = abs(VL);
If the "#include " line is commented out then the code will compile w/o error but the real code this was taken from requires the string headers.
Hi David,
By default the PGI C++ compiler includes the std namespace. Hence, you’re getting a conflict between the std::abs and the abs defined in the C header file stdlib.h. Since “VL” is a double and can be cast to either an int or a long, the compiler doesn’t know which abs you want.
Your options are to add the flag “–no_using_std” to tell the compiler to not use the std namespace by default, or explicitly cast VL to either int or long.
Hope this helps,
Mat
% cat test.cpp
/* abs example */
#include <stdlib.h>
#include <string>
int main ()
double ATOL;
double VL;
VL = 9.9999999;
ATOL = abs((long)VL);
return 0;
% pgcpp test.cpp
"test.cpp", line 7: warning: variable "ATOL" was set but never used
double ATOL;
