Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
Topic Description
Detailed Description
The file setup_python_env.sh
contains the following:
export PYTHONPATH=$PYTHONPATH:$SCRIPT_DIR/../../../$PYTHONPATH:$SCRIPT_DIR/kit/python/lib/python3.10:<more_paths...>
Since Isaac Sim is supposed to be installed in $HOME/isaacsim
, if PYTHONPATH
is empty beforehand, this segment $SCRIPT_DIR/../../../$PYTHONPATH
will end up adding the root directory /
into PYTHONPATH
. Then this means I can import the root path subfolders as packages, e.g.:
user@machine ~/isaacsim$ ./python.sh
Python 3.10.15 (tags/v3.10.15-dirty:ffee63f, Oct 8 2024, 18:53:10) [GCC 7.3.1 20180303 (Red Hat 7.3.1-5)] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import opt
The root folder is also visible in sys.path
>>> import sys
>>> print(sys.path)
['', '/home/user/isaacsim', '/', ...]
This can introduce package import conflicts and confusing behavior depending on the names of subfolders under /
. Is there any reason for this entry into PYTHONPATH
? Also, the LD_LIBRARY_PATH
suffers from the same.
