Looking at the results of lspci for ConnectX-6 (MCX623106AN-CDAT), the First Error Pointer is 04(※). I have some questions regarding this.
(※)Capabilities: [100 v1] Advanced Error Reporting⇒AERCap: First Error Pointer: 04
Configuration: The ConnectX-6 is just installed in the PC, and the other side is not connected. Also, the lspci results were obtained immediately after turning on the PC.
① First Error Pointer: I think 04 indicates a past error, so it shows that an error occurred in bit 4 of the Uncorrectable Error Status Register(UESta), the Data Link Protocol Error Status, during PC startup. Since the value of the Uncorrectable Error Status Register(UESta) is 0, I believe this means that the Uncorrectable Error Status Register(UESta) has been cleared. Is my understanding correct?
② Is the above ① incorrect, and in ConnectX-6, is the value of the First Error Pointer 0x4 by default, meaning that no actual error has occurred?
③ Is it not possible to set the value of the First Error Pointer to 0? I understand that clearing it is not possible. Even after performing an FLR, the value remained 0x4 and did not change.
lspci result
01:00.0 Ethernet controller: Mellanox Technologies MT2892 Family [ConnectX-6 Dx]
Subsystem: Mellanox Technologies MT2892 Family [ConnectX-6 Dx]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 0
Region 0: Memory at 90000000 (64-bit, prefetchable) [size=32M]
Expansion ROM at 94000000 [virtual] [disabled] [size=1M]
Capabilities: [60] Express (v2) Endpoint, IntMsgNum 0
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 512 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM not supported
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, LnkDisable- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 16GT/s, Width x16
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+ NROPrPrP- LTR-
10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
AtomicOpsCtl: ReqEn+
IDOReq- IDOCompl- LTR- EmergencyPowerReductionReq-
10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
LnkCap2: Supported Link Speeds: 2.5-16GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [48] Vital Product Data
Product Name: ConnectX-6 Dx EN adapter card, 100GbE, Dual-port QSFP56, PCIe 4.0 x16, No Crypto
Read-only fields:
[PN] Part number: MCX623106AN-CDAT
[EC] Engineering changes: AH
[V2] Vendor specific: MCX623106AN-CDAT
[SN] Serial number: MT2227J43871
[V3] Vendor specific: a2cd4f278d01ed118000e8ebd368cbfa
[VA] Vendor specific: MLX:MN=MLNX:CSKU=V2:UUID=V3:PCI=V0:MODL=CX623106A
[V0] Vendor specific: PCIeGen4 x16
[VU] Vendor specific: MT2227J43871MLNXS0D0F0
[RV] Reserved: checksum good, 1 byte(s) reserved
End
Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [c0] Vendor Specific Information: Len=18 <\?>
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot-,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 04, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [180 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration- 10BitTagReq- IntMsgNum 0
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+ 10BitTagReq-
IOVSta: Migration-
Initial VFs: 8, Total VFs: 8, Number of VFs: 0, Function Dependency Link: 00
VF offset: 2, stride: 1, Device ID: 101e
Supported Page Size: 000007ff, System Page Size: 00000001
Region 0: Memory at 0000000004100000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1c0 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Capabilities: [230 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [320 v1] Lane Margining at the Receiver
PortCap: Uses Driver-
PortSta: MargReady+ MargSoftReady-
Capabilities: [370 v1] Physical Layer 16.0 GT/s <?>
Capabilities: [420 v1] Data Link Feature <?>
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
