I have double-checked my directory. I’m 100% sure my directory path is correct.
However, when using ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so, It working correctly as well as libnvds_mot_iou.so.
more information
pc@pcde:/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-test5$ ./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt -p 1 -m 2 --gst-debug=2
Creating LL OSD context new
0:00:00.423986651 32226 0x55b8597d0920 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 13]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:01.515100876 32226 0x55b8597d0920 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 12]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:01.548588710 32226 0x55b8597d0920 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 11]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
dlopen error: libcufft.so.10: cannot open shared object file: No such file or directory
gstnvtracker: Failed to initilaize low level lib.
0:00:01.554404996 32226 0x55b8597d0920 ERROR nvtracker gstnvtracker.cpp:232:gst_nv_tracker_start: gstnvtracker: Failed to initialize trackerIface
0:00:01.554420506 32226 0x55b8597d0920 WARN GST_PADS gstpad.c:1149:gst_pad_set_active:<tracking_tracker:sink> Failed to activate pad
** ERROR: <main:1358>: Failed to set pipeline to PAUSED
Quitting
App run failed
configuration
[tracker]
enable=1
tracker-width=600
tracker-height=300
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
# mot_iou
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
#ll-config-file=/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-test5/configs/iou_config.txt
# libnvds_nvdcf
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
ll-config-file=/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-test5/configs/tracker_config.yml
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
Could you explain more about visionworks? Where I can find it?
I try to run the app with sudo and the result is
maxdevpc@maxdevpc:~$ sudo -i
[sudo] password for pc:
root@pc:~# cd /opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-test5
root@pc:/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-test5# ./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt -p 1 -m 2 --gst-debug=2
(gst-plugin-scanner:11579): GStreamer-WARNING **: 23:03:52.692: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libnvjpeg.so.10: cannot open shared object file: No such file or directory
max max max max max max max max max max
0:00:01.055897142 11578 0x55ce44f83060 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 13]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:02.116872570 11578 0x55ce44f83060 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 12]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:02.149898274 11578 0x55ce44f83060 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 11]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:02.154666138 11578 0x55ce44f83060 ERROR nvtracker gstnvtracker.cpp:232:gst_nv_tracker_start: gstnvtracker: Failed to initialize trackerIface
0:00:02.154677618 11578 0x55ce44f83060 WARN GST_PADS gstpad.c:1149:gst_pad_set_active:<tracking_tracker:sink> Failed to activate pad
** ERROR: <main:1359>: Failed to set pipeline to PAUSED
You mean the file in deepstream_sdk_v4.0.1_x86_64.tbz2 → binaries.tbz2 → libnvds_nvdcf.so right?
If this file, I copy and replace the old one with this new one. Then, I try to run the app, the error is the same.
~/.cache/gstreamer-1.0$ ls -al
total 8
drwxrwxr-x 2 pc pc 4096 Nov 26 16:11 .
drwx------ 34 pc pc 4096 Nov 26 15:27 ..
(gst-plugin-scanner:17487): GStreamer-WARNING **: 16:14:52.871: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libnvjpeg.so.10: cannot open shared object file: No such file or directory
0:00:00.715136540 17486 0x562d09ab9920 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 13]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:01.762648775 17486 0x562d09ab9920 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 12]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:01.794977681 17486 0x562d09ab9920 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 11]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
dlopen error: /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so: cannot open shared object file: No such file or directory
0:00:01.799697516 17486 0x562d09ab9920 ERROR nvtracker gstnvtracker.cpp:232:gst_nv_tracker_start: gstnvtracker: Failed to initialize trackerIface
0:00:01.799707676 17486 0x562d09ab9920 WARN GST_PADS gstpad.c:1149:gst_pad_set_active:<tracking_tracker:sink> Failed to activate pad
Quitting
App run failed
Could you share the nvdcf lib which cannot be accessed with me?
Also I suggest you resetup your env and try again, we cannot repro your issue internally.
