Why gstshark-plot result is None
datastream.txt (54 Bytes) metadata.txt (1.8 KB) when i ./gstshark-plot …/…/…/data -s png.
print:
Loading proctime events…
Loading interlatency events…
Loading scheduling events…
Loading framerate events…
Loading bitrate events…
Loading queuelevel events…
Loading cpuusage events…
Processing proctime…
Processing interlatency…
Processing framerate…
Processing scheduling…
Processing cpusage…
Processing bitrate…
Processing queuelevel…
I can not get the result .
datastream.txt->datastream
metadata.txt->metadata
• DeepStream Version5.0
• TensorRT Version
GstShark is an open-source project from Ridgerun. Can you refer to Ridgerun instruction? Embedded Linux
Yes., I am currently looking at the log analysis pipeline output from the console.
In addition, the content of the currently generated file(metadata) is empty
|-- [4.0K] gstshark_2020-07-15_08:38:19
| |-- [2.3M] datastream
| `-- [ 0] metadata
|-- [4.0K] gstshark_2020-07-15_08:41:53
| |-- [488K] datastream
| `-- [ 0] metadata
|-- [4.0K] gstshark_2020-07-15_08:45:41
| |-- [1.3M] datastream
| `-- [ 0] metadata
|-- [4.0K] gstshark_2020-07-15_08:51:16
| |-- [1.5M] datastream
| `-- [ 0] metadata
|-- [4.0K] gstshark_2020-07-15_08:53:53
| |-- [1000K] datastream
| -- [ 0] metadata – [4.0K] gstshark_2020-07-15_08:55:55
|-- [2.1M] datastream
`-- [ 0] metadata
I do not why
@miguel.taylor Can you help to provide some suggestions for this issue?
Solved
I want to delete this topic
But I got this :
You don’t have permission to delete this topic. If you really want it to be deleted, submit a flag for moderator attention together with reasoning.
Thanks for the update, issue closed.
