I am logging into brev from Ubuntu machine:
tance with id/name video-search-and-summarization-blueprint-6ad61a not found
(base) eli@eli-GamingPc:~/Downloads$ sudo bash -c "$(curl -fsSL https://raw.githubusercontent.com/brevdev/brev-cli/main/bin/install-latest.sh)" && brev login
[sudo] password for eli:
Successfully installed brev CLI to /usr/local/bin/brev
▸ Starting Login
Your Device Confirmation Code is 👉 HTMH-MFLN 👈
Browser link: https://brevdev.us.auth0.com/activate?user_code=HTMH-MFLN
Alternatively, get CLI Command ("Login via CLI"): https://console.brev.dev/profile?login=cli
▸ Press Enter to login via browser
Waiting for login to complete in browser...
Gtk-Message: 13:48:19.082: Not loading module "atk-bridge": The functionality is provided by GTK natively. Please try to not load it.
[376972, Main Thread] WARNING: GTK+ module /snap/firefox/5783/gnome-platform/usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so cannot be loaded.
GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported.: 'glib warning', file /build/firefox/parts/firefox/build/toolkit/xre/nsSigHandlers.cpp:201
(firefox_firefox:376972): Gtk-WARNING **: 13:48:19.122: GTK+ module /snap/firefox/5783/gnome-platform/usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so cannot be loaded.
Gtk-Message: 13:48:19.122: Failed to load module "canberra-gtk-module"
▸ Successfully logged in.
✔ VSCode
current organization: elias-0-hq
create an instance:
(base) eli@eli-GamingPc:~/Downloads$ brev shell video-search-and-summarization-blueprint-6ad61a
instance with id/name video-search-and-summarization-blueprint-6ad61a not found
It says instance not found even though the instance is there
