Why I can`t install the driver on Vista 32 bit?
im new to cuda and all this and i tried to install it on my laptop “ASUS K40IN” it has windows vista 32
I tried to install the drivers from nvidia website directly more than 4 times and tried to install the cuda drivers many times too but i get the same error message
The NVIDIA Setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit."
What is the meaning of that ?? My VGA is G102M
Is there someone help me or maybe NVDIA concern my problem and willing to answer my question
tq :rolleyes:
http://laptopvideo2go.com/ has the installs of CUDA modified for laptops.
I had a similar problem today and followed this steps:
  1. Install a new NVIDIA driver for Windows, version 185+. You can find it in http://www.nvidia.com/content/DriverDownlo…ype=GeForce%20M
  2. If you are working in a notebook, I suggest you to install the CUDA driver 2.2 for notebooks. Otherwise, work with version 2.3 General.
  3. Continue installing the CUDA toolkit and SDK, depending on the version you are working with.
Hope this will help you.
Best,
