I had that exact problem in the past too, I think it was caused by using the wrong bayer pattern. The ISP only supports a few, so I had to adjust my camera’s readout to match.
please check the attach image file,
you could also refer to the format configurations on the top-right. External Media
by the way,
according to your debayer result,
I think there’s should be some buffer alignment issue. (additional vertical line on the right-hand side)
could you please confirm the test-pattern output resolution,
thanks
I can not upload the source raw file.maybe it is large 4.0M.
I upload test.zip for compressor test.raw file.
I confirm the test-pattern output resolution is 1920 x1080.
