Why is DLSS still blocked on Jetson Orin? We are forced to use AMD FSR instead
Why does NVIDIA keep blocking DLSS support on the Jetson Orin Nano and AGX Orin series through the JetPack software?
The argument about architectural limitations doesn’t hold up anymore, and we know these chips have powerful Tensor Cores. Because of this artificial software lock, the independent developer and DIY console community is actively injecting AMD FSR (FidelityFX Super Resolution) into Jetson boards via Proton/Wine just to achieve playable frame rates in 3D simulations and emulation projects.
It is highly ironic that customers who spend a lot of money on a premium NVIDIA ecosystem are forced to rely on your main competitor’s technology (AMD) to get decent scaling performance.
There is no risk of market cannibalization here. People who want a plug-and-play gaming PC will always buy a GeForce RTX card. Those buying a Jetson just want to unlock the full potential of the silicon they paid for.
Please, unlock DLSS for JetPack. Don’t let your own users rely on your competitor’s tech to fix performance gaps.
DLSS needs ray tracing and Orin does not support ray tracing. This is hardware constraint. DLSS requires a RTX graphic card. If you need the feature, please use dGPU platforms.
With all due respect, that architectural claim is inaccurate.
DLSS is a deep learning-based upscaling technology that runs exclusively on Tensor Cores, not RT Cores.
The Jetson AGX Orin features an Ampere-based GPU equipped with 64 Tensor Cores, delivering up to 275 TOPS of AI performance. RT Cores are dedicated strictly to bounding volume hierarchy (BVH) ray-triangle intersection testing for lighting and shadows—calculations that are completely independent of DLSS’s neural network reconstruction. Historically, even architectures without RT Cores (like Volta/Titan V) were capable of executing early iterations of DLSS algorithms precisely because they possessed Tensor Cores.
Furthermore, it is widely documented in the industry that Nintendo’s upcoming hardware utilizes a custom SoC derived directly from the Jetson Orin architecture (the T239 chip), which officially supports DLSS.
Asserting that Orin has a hardware constraint preventing DLSS execution is a misdirection. This is a deliberate, artificial software lock enforced via drivers to segment the market between embedded platforms and consumer dGPUs.
If third-party open-source upscalers like AMD FSR can run flawlessly on Jetson platforms via Proton/Wine layers, there is no technical justification for NVIDIA to restrict its own proprietary AI technology on hardware that was explicitly engineered to accelerate neural networks.
You are correct. We do support ray tracing on Orin series. My apology for incorrect information. DLSS is not supported on Jetson platforms. Please us dGPU platforms.
Hello, DaneLLL,
With all due respect, telling developers to “use dGPU platforms” completely misses the engineering constraints of embedded design. You cannot fit a 200W desktop discrete GPU into a handheld DIY console, a portable emulation device, or a compact robotics chassis.
The independent developer community is actively using Jetson Orin boards to build custom, low-power hardware. Restricting DLSS on this architecture—especially when we know the silicon is perfectly capable of running it—only forces us to patch and inject AMD’s FSR just to get playable frame rates.
The hardware is there, the Tensor Cores are there, and the handheld/SBC use case is real. Blocking it via drivers is just hindering innovation in the compact form-factor community.
To the viewers tracking this thread:
Now that the official support has conceded that Orin does support Ray Tracing and the hardware constraints narrative has fallen apart, let’s talk about the elephant in the room that NVIDIA doesn’t want you to know.
The software stack required to run DLSS on this exact ARM64/Linux Ampere silicon already exists and has been fully engineered by NVIDIA.
For those unfamiliar with the background, the massive 2022 NVIDIA source code leaks exposed the development of the NVN2 graphics API tailored for the T239 (Drake) SoC—a custom chip directly derived from the Jetson Orin’s Ampere architecture. The leaked source directories explicitly contained:
  • Native ARM64-compiled nvn2_dlss.dls firmware components.
  • A complete DLSS reconstruction pipeline optimized for the exact same Tegra-based Tensor Core layouts we have on our Orin developer kits.
NVIDIA doesn’t need to spend millions of dollars porting DLSS to Jetson platforms; they have already done the heavy lifting for their console partners.
The response telling us to “use dGPU platforms” proves this is a 100% artificial corporate lockdown. They are artificially crippling a 275 TOPS AI powerhouse just to protect their consumer desktop graphics card sales. As a result, developers trying to build compact, low-power emulation boxes or next-gen handhelds are ironially forced to use AMD FSR—a competitor’s open-source spatial upscaler—on premium NVIDIA AI hardware.
This is pure market segmentation at the expense of the developer community. If you want to see true AI hardware running native AI features without arbitrary software locks, we need to keep making noise.
