Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
5.1.0(installed via offline installation package
Windows 11
GPU Information
- Model: NVIDIA GeForce RTX 4080 Laptop GPU
- Driver Version: 591.74
Topic Description
Detailed Description
After I downloaded the installation package from the official link and clicked on isaac-sim.bat, I noticed that the log kept flashing and reporting errors frequently. In the popped-up Stage panel, there were models but the screen was black, the FPS was 0, and the auxiliary lines were not displayed.
Steps to Reproduce
Download the installation package from NVIDIA’s quick installation documentation
After extracting the compressed file to the D drive, click on isaac-sim.selector.bat
Error Messages
The log content before running the “isaac-sim.bat” file:
Loading user config located at: ‘C:/Users/MUJUO/AppData/Local/ov/data/Kit/Isaac-Sim Full/5.1/user.config.json’
[Info] [carb] Logging to file: C:/Users/MUJUO/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/5.1/kit_20260223_143739.log
2026-02-23T06:37:40Z [3ms] [Warning] [carb.crashreporter-breakpad.plugin] Failed to parse toml file ‘C:/Users/MUJUO/AppData/Local/ov/data/Kit/Isaac-Sim Full/5.1/06a86a0d-3f8f-4496-ad92-b525e80af57b.dmp.toml’: C:/Users/MUJUO/AppData/Local/ov/data/Kit/Isaac-Sim Full/5.1/06a86a0d-3f8f-4496-ad92-b525e80af57b.dmp.toml could not be opened for parsing
2026-02-23T06:37:40Z [4ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/MUJUO/AppData/Local/ov/data/Kit/Isaac-Sim Full/5.1/06a86a0d-3f8f-4496-ad92-b525e80af57b.dmp’
2026-02-23T06:37:40Z [5ms] [Warning] [carb.crashreporter-breakpad.plugin] Failed to parse toml file ‘C:/Users/MUJUO/AppData/Local/ov/data/Kit/Isaac-Sim Full/5.1/c97862c8-c180-4105-a59d-ca7582526ae2.dmp.toml’: C:/Users/MUJUO/AppData/Local/ov/data/Kit/Isaac-Sim Full/5.1/c97862c8-c180-4105-a59d-ca7582526ae2.dmp.toml could not be opened for parsing
2026-02-23T06:37:40Z [7ms] [Warning] [carb.crashreporter-breakpad.plugin] [previous crash] preventing upload of minidump due to user opt-out: ‘C:/Users/MUJUO/AppData/Local/ov/data/Kit/Isaac-Sim Full/5.1/c97862c8-c180-4105-a59d-ca7582526ae2.dmp’
[8.367s] [ext: omni.kit.async_engine-0.0.3] startup
[9.633s] [ext: omni.metrics.core-0.0.3] startup
[9.783s] [ext: omni.client.lib-1.1.0] startup
[10.739s] [ext: omni.blobkey-1.1.2] startup
[10.945s] [ext: omni.stats-1.0.1] startup
[11.180s] [ext: omni.datastore-0.0.0] startup
[11.463s] [ext: omni.client-1.3.0] startup
[11.890s] [ext: omni.ujitso.default-1.0.0] startup
[12.271s] [ext: omni.hsscclient-1.1.2] startup
[12.652s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[12.946s] [ext: omni.assets.plugins-0.0.0] startup
[13.591s] [ext: omni.gpu_foundation-0.0.0] startup
[17.671s] [ext: carb.windowing.plugins-1.0.0] startup
[18.486s] [ext: omni.kit.renderer.init-0.0.0] startup
[18.661s] [ext: omni.kit.pipapi-0.0.0] startup
[18.724s] [ext: omni.kit.pip_archive-0.0.0] startup
[18.755s] [ext: omni.pip.compute-1.6.3] startup
[18.767s] [ext: omni.materialx.libs-1.0.7] startup
[19.448s] [ext: omni.pip.cloud-1.4.3] startup
[19.475s] [ext: omni.isaac.core_archive-3.0.0] startup
[19.487s] [ext: omni.usd.config-1.0.6] startup
[19.535s] [ext: omni.gpucompute.plugins-0.0.0] startup
[26.278s] [ext: omni.usd.libs-1.0.1] startup
2026-02-23T06:38:10Z [30,520ms] [Error] [carb.graphics-vulkan.plugin] Flags 0x6 must be the same for both device and instance.
2026-02-23T06:38:11Z [30,992ms] [Error] [carb.graphics-vulkan.plugin] Flags 0x6 must be the same for both device and instance.
| Driver Version: 580.97 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4080 Laptop.. | Yes: 0 | | 11997 MB | 10de | e51d0100.. |
| | | | | | 27e0 | dcca6940.. |
| | | | | | 1 | |
| 1 | Microsoft Direct3D12 (NVIDIA G.. | Yes: 1 | | 11997 MB | 10de | e51d0100.. |
| | | | | | 27e0 | 73dec6df.. |
| | | | | | N/A | |
| OS: Windows 11 Pro, Version: 10.0 (25H2), Build: 26200, Kernel: 10.0.26100.7623
| Processor: Intel(R) Core™ i9-14900HX
| Cores: 24 | Logical Cores: 32
| Total Memory (MB): 32412 | Free Memory: 22652
| Total Page/Swap (MB): 37276 | Free Page/Swap: 26628
2026-02-23T06:38:11Z [31,611ms] [Error] [carb.graphics-vulkan.plugin] VK_EXT_memory_budget is not supported on this platform. Can’t get the VRAM memory usage info
2026-02-23T06:38:11Z [31,612ms] [Warning] [gpu.foundation.plugin] ResourceAllocator: Can’t get memory usage info. All unused memory will be released
…(repeat 3 times)
[38.235s] [ext: omni.services.pip_archive-0.16.0] startup
[38.255s] [ext: omni.mdl-56.0.3] startup
2026-02-23T06:38:15Z [35,624ms] [Error] [carb.graphics-vulkan.plugin] VK_EXT_memory_budget is not supported on this platform. Can’t get the VRAM memory usage info
2026-02-23T06:38:15Z [35,625ms] [Warning] [gpu.foundation.plugin] ResourceAllocator: Can’t get memory usage info. All unused memory will be released
Then there was a continuous stream of error messages flashing on the screen:
…(repeat 18 times)
[57.470s] [ext: omni.isaac.ml_archive-3.0.4] startup
[57.499s] [ext: omni.kit.loop-isaac-1.3.7] startup
[57.672s] [ext: omni.kit.test-2.0.1] startup
2026-02-23T06:38:34Z [54,728ms] [Error] [carb.graphics-vulkan.plugin] VK_EXT_memory_budget is not supported on this platform. Can’t get the VRAM memory usage info
2026-02-23T06:38:34Z [54,736ms] [Warning] [gpu.foundation.plugin] ResourceAllocator: Can’t get memory usage info. All unused memory will be released
…(repeat 3 times)
[61.501s] [ext: omni.appwindow-1.1.10] startup
[61.731s] [ext: omni.kit.renderer.core-1.1.0] startup
2026-02-23T06:38:38Z [58,747ms] [Error] [carb.graphics-vulkan.plugin] VK_EXT_memory_budget is not supported on this platform. Can’t get the VRAM memory usage info
2026-02-23T06:38:38Z [58,750ms] [Warning] [gpu.foundation.plugin] ResourceAllocator: Can’t get memory usage info. All unused memory will be released
…(repeat 3 times)
[65.293s] [ext: omni.kit.mainwindow-1.0.3] startup
[65.371s] [ext: carb.audio-0.1.0] startup
[65.573s] [ext: omni.uiaudio-1.0.0] startup
[65.831s] [ext: omni.kit.uiapp-0.0.0] startup
[65.833s] [ext: omni.usd.schema.metrics.assembler-107.3.1] startup
2026-02-23T06:38:42Z [62,756ms] [Error] [carb.graphics-vulkan.plugin] VK_EXT_memory_budget is not supported on this platform. Can’t get the VRAM memory usage info
2026-02-23T06:38:42Z [62,758ms] [Warning] [gpu.foundation.plugin] ResourceAllocator: Can’t get memory usage info. All unused memory will be released
…(repeat)
[132.742s] [ext: isaacsim.core.utils-3.5.1] startup
[133.009s] [ext: omni.graph-1.141.2] startup
2026-02-23T06:39:50Z [130,320ms] [Error] [carb.graphics-vulkan.plugin] VK_EXT_memory_budget is not supported on this platform. Can’t get the VRAM memory usage info
2026-02-23T06:39:50Z [130,322ms] [Warning] [gpu.foundation.plugin] ResourceAllocator: Can’t get memory usage info. All unused memory will be released
2026-02-23T06:39:51Z [131,326ms] [Error] [carb.graphics-vulkan.plugin] VK_EXT_memory_budget is not supported on this platform. Can’t get the VRAM memory usage info
2026-02-23T06:39:51Z [131,328ms] [Warning] [gpu.foundation.plugin] ResourceAllocator: Can’t get memory usage info. All unused memory will be released
…(repeat)
Screenshots or Videos
screenshots
What I’ve Tried
- I reduced the version of my driver from 591.86 to 581.57.
- I double-clicked the “isaac-sim.selector.bat” file in the D:\IsaacSim folder to reopen the application selector. Then, I added parameters in the “Extra Args” section. In the “Extra Args” input box, I entered “–vulkan=false” and clicked “START” to start. In the “Extra Args” input box of the App Selector, I changed the parameters to “–vulkan=false --/renderer/activeGpu=0” in an attempt to force DirectX rendering and to force the use of the NVIDIA dedicated GPU. However, it still failed.
- In the “Property” panel on the right, the “Intensity” (brightness) is set to 3000 by default, which is already sufficient to illuminate the scene. I then clicked the RTX-Real-Time button at the top right corner of the viewport, switched the rendering mode, and then returned to it, attempting to force a refresh of the rendered image, but there was still no change.
- I then entered the following in the Extra Args section of the App Selector:
–vulkan=false --/renderer/activeGpu=0 --disable-extensions omni.vulkan.loader
I attempted to directly disable the plugin that calls the Vulkan interface, hoping to stop the terminal from displaying these errors. However, there was no change. - I tried dragging a robot model named Agibot from the Content panel at the bottom left to the center of the viewport, but the color remained unchanged no matter how I moved it.
- I updated the driver to version 580.97 and gave it another try, but there was still no change.
- I right-clicked on isaac-sim.bat and opened it with Notepad. Then I added the startup parameter --/renderer/useRaytracing=false to the last line, but it was still a black screen.
- I opened D:\isaacsim\isaac-sim.bat in Notepad and added the parameters --/content/useLocalCache=true --/content/localCachePath=D:/isaacsim/kit/resources/isaac-sim-assets-complete-5.1.0 at the end of the startup command. Then I saved it. After running this modified .bat script to start the software, there was still no change.
- I removed the checkmark in front of the read-only attribute of the folder.
Then, in the confirmation window that popped up, I chose “Apply the changes to this folder, subfolders and files”, and waited for the system to complete the attribute modification. After that, I closed Isaac Sim and re-ran the modified isaac-sim.bat. Still, there was no change. - I tried to click the top menu “File” “New” to create a completely new blank scene.
Nothing happened. Then I clicked “Create” “Mesh” “Cube” to create a simple cube in the scene. There was a slight change. The light source is not working, the auxiliary lines are not present either, and the FPS remains at 0. - I tried to modify the last line of isaac-sim.bat and replace it with this:
call “%~dp0kit\kit.exe” “%~dp0apps/isaacsim.exp.full.kit” --/renderer/useRaytracing=false --/renderer/usePathTracing=false --/renderer/useRTXRasterization=true --/renderer/useDlss=false --/content/useLocalCache=true --/content/localCachePath=D:/isaacsim/kit/resources/isaac-sim-assets-complete-5.1.0 --/viewport/renderMode=rtxRasterization. However, there is still no change. - Later, I also disabled the advanced Optimus feature in the BIOS, which made the laptop use only the dedicated GPU RTX 4080. However, there was no change.
- I have updated the driver to the latest version 591.74, and there are no changes.
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here
