Why is my softroce bandwidth (2Gbps) much lower than the tcp bandwidth(10Gbps)?
My softroce bandwidth (2Gbps) is much lower than the tcp bandwidth (10Gbps). Is it correct?How much are your softroce bandwidth and tcp/ip bandwidth?
Hello Qi,
Many thanks for posting your inquiry on the Mellanox Community.
Based on the information provided in a previous Community Post, this request should be re-directed to SoftROCE community → https://github.com/SoftRoCE/rxe-dev/wiki/rxe-dev:-Home
Also make sure that when you do the test with SOFTRoCE, no OFED is installed.
Additional note: Configuring SoftROCE for RHEL 7 → https://access.redhat.com/documentation/en-us/red_hat_enterprise_linux/7/html/networking_guide/sec-configuring_soft-_roce
For further information regarding to SoftROCE for your network adapter, please reach out to your vendor in case you are not using Mellanox adapters.
Many thanks,
~Mellanox Technical Support
