If I don’t populate my objects’s rect_params the tracker (nvdcf) doesn’t track the objects. I would’ve assumed it should use detector_bbox_info?
I don’t want to display a bounding boxes for this type of object in the OSD. Even if I set border to 0 it still displays a label for the object. I think my only option is to remove the object before the OSD.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
470.63.01
Bugs
Create own object to be tracked before tracker:
NvDsObjectMeta* objectMeta = nvds_acquire_obj_meta_from_pool(batchMeta);
NvBbox_Coords& box = objectMeta->detector_bbox_info.org_bbox_coords;
box.left = 100.0f;
box.top = 100.0f;
box.width = 200.0f;
box.height = 200.0f;
// Unless you fill in NvOSD_RectParams tracker will not track the object
// However this will cause the object to be rendered on the OSD
NvOSD_RectParams& rectParams = objectMeta->rect_params;
rectParams.left = 100.0f;
rectParams.top = 100.0f;
rectParams.width = 200.0f;
rectParams.height = 200.0f;
nvds_add_obj_meta_to_frame(frameMeta, objectMeta, NULL);
Run nvtracker
Parse result:
If NvOSD_RectParams is NOT filled in object_id will be 0, if NvOSD_RectParams is filled in the object will get an ID.
nvtracker
