Hello, I use R28.2 in tx1, the power consumption will be significantly higher than R28.1. What causes the obvious difference between the two power consumption? Thank you!
shuuchao,
How do you measure the power consumption? Also, what usecase are you working on?
Hello, it is caused by the application.
