I ran the .sh command in the sample, but the generated resnetV150_TRTINT8.pb and resnetV150_TRTINT8Calib.pb are both as large as 205.1MB. I think it is unreasonable as the frozen pb file is just 102.6MB. I am wondering whether someone else met with the same issue.
My system environment is as below:
OS: Ubuntu 16.04
Cuda: 9.0
CuDNN: 7.0.5
Python: 3.5.2
Tensorflow: 1.12.0
TensorRT: 4.0.1.6
GPU: K40
I have two questions about this issue:
What may be the reason for the unexpected calibrated model file size?
I want to check the calibrated weight values in the pb file. It seems that the net parameters are packed into the TrtEngineOp. How can I export the calibrated int8 weights in it?
Thanks for your kind reply.Your answer helped me a lot!
TFTRT did write a new .pb file with TRTEngine in my test.It can be ran much more efficiently than FP32 version, which means that the int8 calibration has been taken.
I just read this post, and I want to ask where can I find other examples of TensorRT.
I just can download this example but can’t access the website that contains this sample!
