Why is the execution time of cudaMalloc so variable (when using hotspot benchmark from Rodinia Benchmark suite)?
I experimented with MPS on the hotspot CUDA application from the Rodinia-3.1 benchmark suite. A clone of that is maintained in my Git Hub.
(with MPS Enabled on the Linux System)
cuda/hotspot$ make
cuda/hotspot$ sudo nsys profile -o MPS-2-1 hotspot_launch.sh 2
The naming convention of the nsys output file used by me is as follows:
MPS-<no_of_invocation_to_hotspot>-<interaction number>
So, the above MPS-2-1 means launched hotspot 2 times under MPS for the first time. MPS-2-4 means launched hotspot 2 times under MPS for the fourth time. (The nsys report files are present in rodinia-3.1-hotspot/cuda/hotspot/MPS_NSYS_REPORTS)
But, I noticed a huge variability in the cudaMalloc time.
For instance:
  1. First Iteration:
    The first cudaMalloc takes 184.398 ms, while the second cudaMalloc takes 172.541 ms
  2. Second Iteration:
    The first cudaMalloc takes 58.08 ms, while the second cudaMalloc takes 168.570 ms
  3. Third Iteration:
    The first cudaMalloc takes 168.320 ms, while the second cudaMalloc takes 60.238 ms
And so on… Why is there this amount of variability?
Now I disable MPS and run the same experiments and profile them.
(with MPS disabled on the Linux System)
cuda/hotspot$ sudo nsys profile -o NO-MPS-2-1 hotspot_launch.sh 2
NO-MPS-<no_of_invocation_to_hotspot>-<interaction number>
So, the above NO-MPS-2-1 means launched hotspot 2 times under no MPS (time-slicing) for the first time. (The nsys report files are present in rodinia-3.1-hotspot/cuda/hotspot/NO_MPS_NSYS_REPORTS)
Now the time of cudaMalloc seems to be double of what was reported with MPS enabled.
  1. First Iteration:
    The first cudaMalloc takes 239.444 ms, while the second cudaMalloc takes 223.165 ms.
    The first cudaMalloc takes 253.195 ms, while the second cudaMalloc takes 244.965 ms.
Possible reasons for variability in cudaMalloc time duration:
  1. The first cudaMalloc call in an application may be also one that incurs CUDA initialization overhead.
  2. cudaMalloc is a synchronizing operation. That means it cannot complete until all previous device activity in that context is idle. So viewed from an API perspective, if there is ongoing device activity (kernel execution) when the cudaMalloc call is issued, it will wait there (from an API perspective) until the device is idle.
  3. In a multithreaded situation (and perhaps MPS multi-process), the CUDA runtime may institute locks to serialize certain activity. The acquisition cost of these locks will vary depending on instance specifics.
There may be other reasons for this as well.
For these reasons, canonical advice is to do all device memory allocations early in your application, and keep them out of concurrent work issuance loops/situations.
As an alternative when this is unavoidable, the cuda memory pool system can be investigated.
It is typical that one observes a wide distribution of execution times for allocation requests to dynamic memory allocators. Most allocators, including the CUDA allocator, comprise multiple layers, and typically the cost of an allocation request depends on how deep the allocator has to reach into this hierarchy. This in turn depends on the size of an allocation request, attributes of the allocation request (if any), and the present internal state of the allocator (e.g. fragmentation).
In order to further comment on this specific case one would need to know details of the cudaMalloc() calls associated with these profiles. The cluster of intense “OS runtime libraries” activity associated with each cudaMalloc() call shown suggests to me that these are large allocation causing the allocator to dip down to the deepest (most expensive) allocator layer. However, without knowing the internal details of the CUDA allocator (as far as I know, not documented by NVIDIA, it may well change over time) I am not particular confident in this diagnosis.
Just curious about memcpy-async in a different application (vision_maskrcnn in pytorch using torch.compile)
Why does a host side API call of cudaMemcpyAsync take so long (1 ms 385 us) while the GPU side execution takes just 2.2 us.
Trace from PyTorch Profiler
The same from nsys profile (along with CPU side trace enabled)
Pytorch Profile showing cudaStreamSynchronize call after memcpyAsync
It is not a synchronous API. So I expected the CPU side cudaMemcpyAsync call to be short enough – just the enqueue of the task on the GPU queue for the particular stream. And the expect the cudaStreamSynchronize call following the cudaMemcpyAsync to be long enough to wait for all the tasks in the stream to be completed before proceeding further.
Why is the cudaMemcpyAsync D2H CPU API taking so long? Is some PCIe delay coming into the picture while launching that memcpy task? And hence that CPU side API’s execution time is dependent on the amount of data being transferred or copied?
vision_maskrcnn.zip (891.6 KB)
Please see this documentation regarding asynchronous copies: CUDA Runtime API :: CUDA Toolkit Documentation
From your screenshots one can see that the performed operation copies from device memory to pageable memory. This means the following documentation statement applies:
Asynchronous
  1. For transfers between device memory and pageable host memory, the function might be synchronous with respect to host.
I did not analyze the pretty pictures. If this API is in fact used with pageable host memory (as alleged in the preceding post), it is not following best practices.
This API should only be used with pinned memory so data can be transferred by the GPU’s DMA engines asynchronously to host activity. A transfer to or from paged system memory typically results in a two-step process, involving a DMA transfer between the GPU and a host-side pinned buffer owned by the CUDA driver, plus a copy operation inside the host’s system memory between the driver-owned pinned buffer and the user process’s memory.
If for some reason copy operations on pageable system memory are unavoidable, but very high performance is of the essence, one should deploy CPUs with high system memory throughput (I would suggest more than four memory channels).
