Why is the GX10 performance so poor?
My 4TB/PCIe 5.0 GX10 arrived today, and I excitedly connected it to my LAN, updated the packages, firmware, drivers, and began the work of installing vLLM, ollama and comparing that to my other LLM machines in the homelab.
I couldn’t be more disappointed with the performance. To say it’s poor would be an understatement.
I benchmarked against my M5 MacBook Pro and ollama running in Docker running inside a VMware VM, and my MacBook was roughly 2x the tokens/second, and 5x the overall performance across all Docker and container workloads. My M5 wipes the floor with the GX10.
Runtime / machine Model Wall time Throughput
M5 MacBook Pro / Ollama qwen3:8b ~6.0 s ~87 tok/s
DGX Spark / Ollama qwen3:8b ~11.6 s ~43 tok/s
DGX Spark / vLLM Qwen2.5-7B-Instruct ~36.2 s ~13.8 tok/s
Surely this should be more performant than this. For a nearly $5k machine, I expected much more than I get from my M5 and a VMware VM + Docker.
Yes, the GPU passthrough is working, confirmed outside and inside with nvidia-smi, and it’s using 96% GPU, barely touching the GPU, but it takes almost 2 minutes for qwen3:8b to answer “Tell me a random fact about the Roman empire”. Every time, even after warming.
What non-standard drivers/firmware/packages do I need to install to make this work properly?
The out-of-the-box, default experience is so poor, I either have defective hardware, or the LLMs and tools aren’t yet built/optimized for the GX10.
Thanks in advance for any suggestions/help you can provide!
You should be getting much more performance. Check out the community vllm container, maintained by @eugr_nv GitHub - eugr/spark-vllm-docker: Docker configuration for running VLLM on dual DGX Sparks · GitHub
In addition to @aniculescu post, a couple of things worth mentioning:
  1. Please make sure you run quantized models. Ollama picks 4-bit quantization by default, but the model you listed for vLLM is a full BF16 version that is 4x larger than 4-bit quant. So you need to look for NVFP4 versions, or int4-autoround or AWQ to compare apples-to-apples.
  2. The models you mentioned are outdated. Qwen 3.6 series are the newest available from Qwen.
  3. DGX Spark works better with MoE models. In Qwen 3.6 family, that would be Qwen3.6-35B-A3B. I recommend using nvidia/Qwen3.6-35B-A3B-NVFP4 as it has good accuracy and runs well on Spark. And it also has ready-to-use recipe in both spark-vllm-docker and Sparkrun (another community project that uses spark-vllm-docker vLLM builds, but adds many useful features that makes it even easier to setup and use).
  1. Install sparkrun
  2. Find qwen3 recipes to run sparkrun recipe search qwen3
  3. Run the recipe of your choice for 1 node. For example sparkrun run @eugr/qwen3.6-35b-a3b-nvfp4 (favor nvfp4 if available, or fp8, or )
You can also build your own recipes, based on sparkrun registries or spark-arena
Qwen3.6-35B-A3B-PrismaQuant-MTP-k3-solo-spark-arena-long.yaml
solo_only: true
mods:
  - mods/fix-qwen3.5-autoround
  - mods/fix-qwen3-coder-next
model: rdtand/Qwen3.6-35B-A3B-PrismaQuant-4.75bit-vllm
description: rdtand/Qwen3.6-35B-A3B-PrismaQuant-4.75bit-vllm with native MTP speculation, FP8 KV cache, FlashInfer attention, long-context Spark profile
container: vllm-node-tf5
command: |
  vllm serve rdtand/Qwen3.6-35B-A3B-PrismaQuant-4.75bit-vllm \
    --host {host} \
    --port {port} \
    --served-model-name qwen3.6-35b \
    --max-model-len {max_model_len} \
    --max-num-batched-tokens {max_num_batched_tokens} \
    --max-num-seqs {max_num_seqs} \
    --gpu-memory-utilization {gpu_memory_utilization} \
    --dtype auto \
    --load-format instanttensor \
    --attention-backend flashinfer \
    --enable-prefix-caching \
    --enable-chunked-prefill \
    --trust-remote-code \
    --quantization compressed-tensors \
    --kv-cache-dtype fp8 \
    --reasoning-parser qwen3 \
    --enable-auto-tool-choice \
    --tool-call-parser qwen3_coder \
    --optimization-level 3 \
    --performance-mode throughput \
    --default-chat-template-kwargs '{"preserve_thinking": true}' \
    --speculative-config '{"method":"mtp","num_speculative_tokens": 3}' \
    --override-generation-config '{"temperature":0.6,"top_p":0.95,"top_k":20,"min_p":0.0,"presence_penalty":1.1,"repetition_penalty":1.01}' \
defaults:
  max_num_batched_tokens: 32768
  max_model_len: 262144
  host: 0.0.0.0
  gpu_memory_utilization: 0.6
  max_num_seqs: 4
  port: 8888
cluster_only: false
recipe_version: '2'
env:
  TRANSFORMERS_OFFLINE: '1'
  VLLM_MARLIN_USE_ATOMIC_ADD: '1'
  VLLM_TUNED_CONFIG_FOLDER: /workspace/moe-configs
  VLLM_HTTP_TIMEOUT_KEEP_ALIVE: '600'
  HF_HUB_OFFLINE: '1'
  FLASHINFER_DISABLE_VERSION_CHECK: '1'
Run your custom recipe sparkrun run ./Qwen3.6-35B-A3B-PrismaQuant-MTP-k3-solo-spark-arena-long.yaml
Enjoy!
