The following is a paragraph taken from Website Dr Dobbs
The two programs basically calculate the reverse of an array on GPU; one with shared memory another without shared memory.
Can someone help me in understanding the answer to the above question: Since global memory performance is between 100x-150x slower than shared memory, shouldn’t the significantly slower global memory performance dominate the runtime of both examples? Why is the shared memory version faster?
The two programs, cited above are given below for easy reference:
reverseArray_multiblock.cu
// includes, system
#include <stdio.h>
#include <assert.h>
// Simple utility function to check for CUDA runtime errors
void checkCUDAError(const char* msg);
// Part3: implement the kernel
__global__ void reverseArrayBlock(int *d_out, int *d_in)
int inOffset = blockDim.x * blockIdx.x;
int outOffset = blockDim.x * (gridDim.x - 1 - blockIdx.x);
int in = inOffset + threadIdx.x;
int out = outOffset + (blockDim.x - 1 - threadIdx.x);
d_out[out] = d_in[in];
//////////////////////////////////////////////////////////////////////////////// // Program main ////////////////////////////////////////////////////////////////////////////////
int main( int argc, char** argv)
// pointer for host memory and size
int *h_a;
int dimA = 256 * 1024; // 256K elements (1MB total)
// pointer for device memory
int *d_b, *d_a;
// define grid and block size
int numThreadsPerBlock = 256;
// Part 1: compute number of blocks needed based on array size and desired block size
int numBlocks = dimA / numThreadsPerBlock; // allocate host and device memory
size_t memSize = numBlocks * numThreadsPerBlock * sizeof(int);
h_a = (int *) malloc(memSize);
cudaMalloc( (void **) &d_a, memSize );
cudaMalloc( (void **) &d_b, memSize );
// Initialize input array on host
for (int i = 0; i < dimA; ++i)
{ h_a[i] = i; }
// Copy host array to device array
cudaMemcpy( d_a, h_a, memSize, cudaMemcpyHostToDevice );
// launch kernel dim3 dimGrid(numBlocks);
dim3 dimBlock(numThreadsPerBlock);
reverseArrayBlock<<< dimGrid, dimBlock >>>( d_b, d_a );
// block until the device has completed
cudaThreadSynchronize();
// check if kernel execution generated an error // Check for any CUDA errors
checkCUDAError("kernel invocation");
// device to host copy
cudaMemcpy( h_a, d_b, memSize, cudaMemcpyDeviceToHost );
checkCUDAError("memcpy");
// verify the data returned to the host is correct
for (int i = 0; i < dimA; i++)
assert(h_a[i] == dimA - 1 - i );
// free device memory
cudaFree(d_a);
cudaFree(d_b);
// free host memory free(h_a);
// If the program makes it this far, then the results are correct and // there are no run-time errors. Good work!
printf("Correct!\n"); return 0;
void checkCUDAError(const char *msg)
cudaError_t err = cudaGetLastError();
if( cudaSuccess != err)
fprintf(stderr, "Cuda error: %s: %s.\n", msg, cudaGetErrorString( err) );
exit(EXIT_FAILURE);
reverseArray_multiblock_fast.cu using shared memory
// includes, system
#include <stdio.h>
#include <assert.h>
// Part 2 of 2: implement the fast kernel using shared memory
extern __shared__ int s_data[];
// Load one element per thread from device memory and store it // *in reversed order* into temporary shared memory
s_data[blockDim.x - 1 - threadIdx.x] = d_in[in];
// Block until all threads in the block have written their data to shared mem
__syncthreads();
// write the data from shared memory in forward order, // but to the reversed block offset as before
int out = outOffset + threadIdx.x;
d_out[out] = s_data[threadIdx.x];
{ // pointer for host memory and size
int *h_a;
int *d_b, *d_a;
// Compute number of blocks needed based on array size and desired block size
// Part 1 of 2: Compute the number of bytes of shared memory needed // This is used in the kernel invocation below
int sharedMemSize = numThreadsPerBlock * sizeof(int);
h_a[i] = i;
// launch kernel
reverseArrayBlock<<< dimGrid, dimBlock, sharedMemSize >>>( d_b, d_a );
cudaFree(d_a);
cudaFree(d_b);
return 0;
exit(EXIT_FAILURE); }
