Why is this dot product code not thread safe?
Hello All,
Here’s my dot product code which has shown itself to be variable :
#include <cuda.h>
#include <iostream>
#include <stdio.h>
#define N (2048*2048)
#define THREADS_PER_BLOCK 512
__global__ void dot( int *a, int *b, int *c ) {
    __shared__ int temp[THREADS_PER_BLOCK];
    int index = threadIdx.x + blockIdx.x * blockDim.x;
    temp[threadIdx.x] = a[index] * b[index];
   __syncthreads();
   if( 0 == threadIdx.x ) {
      int sum = 0;
      *c = 0;
      for( int i = 0; i < THREADS_PER_BLOCK; i++ )
         sum += temp[i];
      atomicAdd( c , sum );
   return;
int main(void) {
    int *a, *b, *c;
    int *dev_a, *dev_b, *dev_c;
    int size = N * sizeof( int );
   cudaMalloc((void**)&dev_a, size );
   cudaMalloc((void**)&dev_b, size );
   cudaMalloc((void**)&dev_c, sizeof( int ) );
   a = (int *)malloc( size );
   b = (int *)malloc( size );
   c = (int *)malloc( sizeof( int ) );
   *c = 0;
   for (int i=0; i < N; ++i) {
      a[i] = i;
      b[i] = i;
// copy inputs to device
   cudaMemcpy( dev_a, a, size, cudaMemcpyHostToDevice );
   cudaMemcpy( dev_b, b, size, cudaMemcpyHostToDevice );
// launch dot() kernel
   dot<<< N/THREADS_PER_BLOCK, THREADS_PER_BLOCK >>>( dev_a, dev_b, dev_c );
// copy device result back to host copy of c
   cudaMemcpy( c, dev_c, sizeof( int ) , cudaMemcpyDeviceToHost );
   std::cout << "Result of dot product is : " << *c << std::endl;
   free( a ); free( b ); free( c );
   cudaFree( dev_a );
   cudaFree( dev_b );
   cudaFree( dev_c );
   return 0;
I have no idea why it doesn’t seem to want to work for me but it works fine for small numbers like 2048 as N.
Turns out, I was overflowing the signed integer values. Omg.
My code works with floats though so thank you God almighty :)
I feel silly XD
