Hi guys!
I run the example of martix transpose on windows(gtx940mx) and jetson nano(tegra x1).
Here is the git:https://github.com/NVIDIA-developer-blog/code-samples/blob/master/series/cuda-cpp/transpose/transpose.cu
When I run the program on jetson nano, bandwidth become 2x when using shared memory.
But when the same program runs on gtx940mx, bandwidth become 1/2 when using shared memory.
Theoretically is it normal? Or may be gtx940mx is too bad for CUDA programming?
Here is some information of gtx940mx:
Device 0: "GeForce 940MX"
CUDA Driver Version / Runtime Version 10.1 / 10.1
CUDA Capability Major/Minor version number: 5.0
Total amount of global memory: 2048 MBytes (2147483648 bytes)
( 3) Multiprocessors, (128) CUDA Cores/MP: 384 CUDA Cores
GPU Max Clock rate: 1242 MHz (1.24 GHz)
Memory Clock rate: 1001 Mhz
Memory Bus Width: 64-bit
L2 Cache Size: 1048576 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 4 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: No
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 2 / 0
and Tegra X1:
Device 0: "NVIDIA Tegra X1"
CUDA Capability Major/Minor version number: 5.3
Total amount of global memory: 3964 MBytes (4156932096 bytes)
( 3) Multiprocessors, (128) CUDA Cores/MP: 128 CUDA Cores
GPU Max Clock rate: 922 MHz (0.92 GHz)
Memory Clock rate: 13 Mhz
L2 Cache Size: 262144 bytes
Warp size: 32
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Integrated GPU sharing Host Memory: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
